Hello,
running the r.pack addon I got the follwoing error:
GRASS 6.5.svn (Spearfish60):/usr/local/src/grass-addons/raster/r.pack >
./r.pack
sh: r.pack: not found
File "/usr/local/grass-6.5.svn/etc/wxpython/gui_modules/menuform.py",
line 1891, in <module>
GrassGUIApp( grassTask( sys.argv[1] ) ).MainLoop()
line 313, in __init__
processTask(tree =
etree.fromstring(getInterfaceDescription(grassModule)),
line 1691, in getInterfaceDescription
raise IOError, _("Unable to fetch interface description for command
'%s'.") % cmd
IOError
What could be the cause for this?
Furthermore, would it be feasible to add such a pack command for all
data types (raster, vector, 3D, data bases) to the GRASS main code?
It's very useful when exchanging result files for remote helping or
interchange.
e.g. put it or symlink it into $GRASS_ADDON_PATH. see 'g.manual variables'
interchange.
maybe for grass7 once we get the raster format reordered.
for vectors you can just copy the map's directory, for databases "it depends", for DBF easy, for other's you need to g.copy into a fresh
mapset and check db links are relative paths not hardcoded paths.
for now the recommended way is to create a new mapset, g.copy in the
maps you want to transfer, and then package that up with the PERMANENT
mapset into a tarball or zip file.
