[GRASS-user] Export Raster to Google Earth Files
Hi Everyone,
I would like to export raster files to a Google Earth image (kmz or kml). Does anyone know how this is done? I found a way to export a vector to a kmz file, but not a raster.
Your help is very much appreciated.
Best,
Andrew
Andrew Lewin, M.Sc., Adv. Dipl. GIS
Email: andrew.lewin@sympatico.ca
Tel: (905) 639-4646
Mobile: (905) 630-8441
Skype: andrew.lewin99
raster.
try http://grass.osgeo.org/wiki/GRASS_AddOns#r.out.gmap
easier:
I think you just have to export a geotiff then compose the KM? file
manually with the bounds.
Hamish
Hamish wrote:
easier:
Or you can use gdal2tiles.py to do this bit. It will also create different zoom levels for you.
More information on a previous posting:
http://lists.osgeo.org/pipermail/grass-user/2009-May/050361.html
John
Dr John Stevenson
Postdoctoral Research Associate
School of Earth, Atmospheric and Environmental Sciences
Williamson Building (Room 2.42)
University of Manchester
Manchester M13 9PL, UK
tel. +44(0)161 306 6585; fax. +44(0)161 306 9361;
john.stevenson@manchester.ac.uk
The easiest way to do this for 1 or 2 reasonably sized rasters is to
simply write a very short KML file that points to the image name and
defines its geographic extents. If you have to do it for hundreds of
files, then scripting it is much faster. I can send you a short Perl
script that uses gdalinfo to determine the extents. Here is what the
KML should look like:
<GroundOverlay>
<description>Something pithy</description>
<name>Something else pithy</name>
<visibility>1</visibility>
<open>1</open>
<Icon>
<href>"name_of_image_file"</href>
</Icon>
<drawOrder>0</drawOrder>
<LatLonBox>
<north> DD.dddd</north>
<south> DD.dddd</south>
<west> DD.dddd</west>
<east> DD.dddd</east>
</LatLonBox>
</GroundOverlay>
Roger
On Tue, Oct 13, 2009 at 11:14 AM, Andrew Lewin
<andrew.lewin@sympatico.ca> wrote:
Hi Everyone,
Best,
Andrew
Tel: (905) 639-4646
grass-user mailing list
grass-user@lists.osgeo.org
> image (kmz or kml).
is to simply write a very short KML file that points to the
image name and defines its geographic extents. If you have to
do it for hundreds of files, then scripting it is much
faster.
Here is what the KML should look like:
<GroundOverlay>
<open>1</open>
<Icon>
</Icon>
<LatLonBox>
</LatLonBox>
</GroundOverlay>
based on this template I've added a r.out.kml script in addons
SVN to do that.
https://trac.osgeo.org/grass/browser/grass-addons/raster/r.out.kml
TODO:
- completely untested
- g.region -n is broken in at least devbr6 (trac #791) so
   export only works from LL/WGS84 right now
- pythonization
- add a -k flag to d.out.file to write a KML file (test true north angle(s)!)
comments/testing/suggestions welcome.
Hamish
lol Awesome! Can you imagine ESRI creating a utility this way?
Thanks for doing this.
Roger
On Fri, Oct 16, 2009 at 8:36 PM, Hamish <hamish_b@yahoo.com> wrote:
> image (kmz or kml).
faster.
<GroundOverlay>
<open>1</open>
<Icon>
</Icon>
<LatLonBox>
</LatLonBox>
</GroundOverlay>
SVN to do that.
TODO:
- pythonization
Hamish
