[GRASS-user] exporting maps via gdal
trying to export some floating point map (result of interpolation) to
geotiff via gdal:
    r.out.gdal in=ca2005 out=ca2005.tif type=Float32
result is, that the map is displayed as "black" e.g. in qgis and
mapserver is not able to display anything :frowning:
how to export floating point maps, so they can be read later by other programs
(which are using gdal too)?
when I import the map back
    r.in.gdal in=ca2005.tif out=pokus, everything seems to be allright
Jachym
Jachym Cepicky
e-mail: jachym.cepicky@centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/jachym_cepicky-gpg_public_key.asc
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
e-mail: cepicky@gdf-hannover.de
URL: http://gdf-hannover.de
Tel.: +49 511-39088507
Jachym Cepicky wrote on 07/17/2006 03:43 PM:
geotiff via gdal:
Jachym,
you could try to export to ERDAS/IMG format (format=HFA).
Maybe then the color tables is preserved.
Jachym
> Hi,
> geotiff via gdal:
Jachym,
hmm, problem is, that the map can not be displayed via mapserver - how
do you export any floting point geotiff ?
thanks
    jachym
> :frowning:
> Jachym
grassuser mailing list
grassuser@grass.itc.it
Jachym Cepicky
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
Jachym,
> > geotiff via gdal:
> Jachym,
> Markus
thanks
    jachym
The r.out.gdal output *can* be displayed with mapserver but, since it
has no associated color palette (that mapserver can understand
anyhow), mapserver will render it in a black->white color ramp. If
your data values are very skewed, it may appear all black. Try using
the SCALE processing directive to set the min and max of the b&w color
ramp. (http://mapserver.gis.umn.edu/docs/howto/raster_data/#special-processing-directives)
Also, Have you tried r.out.tiff ? This will export a colored image of
your data at the current region settings. The resulting tiff will not
contain actual values but will look as it did in grass.
r.out.tiff -t input=elevation.dem output=elev
You can use the r.out.tiff output for display purposes and the
r.out.gdal output for query purposes.
Finally you might want to try reading the grass raster directly from
mapserver and avoid the conversion step altogether.
Matt Perry
perrygeo@gmail.com
http://www.perrygeo.net
thanks for hints
we will see
jachym
On Mon, Jul 17, 2006 at 10:41:17AM -0700, Matthew Perry wrote:
Jachym,
>> > geotiff via gdal:
>> Jachym,
>> Markus
>thanks
> jachym
ramp.
Matt Perry
perrygeo@gmail.com
Jachym Cepicky
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
