I'm exporting some data from Grass 6.4 to QGis as .asc files. The source
location has the projection:
g.proj -p
-PROJ_INFO-------------------------------------------------
proj : ll
datum : wgs84
ellps : wgs84
no_defs : defined
-PROJ_UNITS------------------------------------------------
unit : degree
units : degrees
meters : 1.0
I generated the asc file with:
r.out.ascii input=tri_median@PERMANENT output=tri_median.asc
When I import this into QGis, the layer is flipped east to west - the
atlantic coast of NA appears on the west, rather than the east!
The header appears correct:
tws:~$ head -6 tri_mean.asc
north: 46:53:04.633938N
south: 34:44:13.536462N
east: 68:50:28.1616W
west: 94:51:40.938811W
rows: 1458
cols: 3122
But gdal mis-reads it:
tws:~$ gdalinfo tri_mean.asc
Driver: GRASSASCIIGrid/GRASS ASCII Grid
Files: tri_mean.asc
Size is 3122, 1458
Coordinate System is `'
Origin = (94.000000000000000,46.000000000000000)
Pixel Size = (-0.008327994875080,-0.008230452674897)
Corner Coordinates:
Upper Left ( 94.0000000, 46.0000000)
Lower Left ( 94.0000000, 34.0000000)
Upper Right ( 68.0000000, 46.0000000)
Lower Right ( 68.0000000, 34.0000000)
Center ( 81.0000000, 40.0000000)
Band 1 Block=3122x1 Type=Float32, ColorInterp=Undefined
I can correct this by manually replacing the east and west values with
negative numbers, dropping the "W".
Have I done something wrong somewhere, or is there a problem with the
Grass 6.4 export or QGis/gdal import?
Thanks!
Tyler Smith
plantarum.ca
Tyler Smith:
g.proj -p
proj : ll
datum : wgs84
ellps : wgs84
no_defs : defined
unit : degree
units : degrees
meters : 1.0
What does `g.region -p` say about?
rows: 1458
cols: 3122
Shouldn't it be:
east: 94:51:40.938811W
west: 68:50:28.1616W
( east > west )
Nikos
Files: tri_mean.asc
Size is 3122, 1458
Corner Coordinates:
Thanks!
g.region -p rast=tri_median@PERMANENT
projection: 3 (Latitude-Longitude)
zone: 0
datum: wgs84
ellipsoid: wgs84
nsres: 0:00:29.993894
ewres: 0:00:30.004093
rows: 1458
cols: 3122
cells: 4551876
Shouldn't it be:
( east > west )
Not in this case - note that the east boundary is 68 degrees WEST, which
is further east than the west boundary at 94 degrees WEST.
Also, my crude fix of replacing 94:51:40.93W with -94:51:40.93 in the
asc header didn't really fix the problem - the projection still doesn't
quite match up with the destination in QGis.
Tyler
* Tyler Smith <tyler@plantarum.ca> [2015-05-08 14:34:41 -0400]:
zone: 0
datum: wgs84
ellipsoid: wgs84
rows: 1458
cols: 3122
cells: 4551876
> Shouldn't it be:
> ( east > west )
I see. Then it is correct :-). I am trying to do some test with your
region settings (with res=30). The exported file (just some random cells set to 100)
begins with:
north: 46:53:30N
south: 34:44N
east: 68:50W
west: 94:52W
rows: 1459
cols: 3124
which is correct and gdalinfo reports:
Files: test_random_points
Size is 3124, 1459
Pixel Size = (-0.008322663252241,-0.008224811514736)
Corner Coordinates:
Band 1 Block=3124x1 Type=Int32, ColorInterp=Undefined
So the same. Maybe ask in gdal-dev?
Nikos
Tyler
