I’m trying to classify a LANDSAT8 image. In the process, i’d like to export an unsupervised classification i did (using i.cluster, followed by i.maxlik) raster (type:CELL) into kml/kmz, so that I could get some visual idea of the classification. the classification is from 1 to 10, with null data present.
r.out.gdal -c input=lsat2014_unsupervised@PERMANENT output=C:\Users\Vishal\Documents\GIS\file3.kmz format=KMLSUPEROVERLAY type=Byte nodata=0
but no matter what flags i try, i get a black box on google earth.
I’m just using the GUI options, Grass7svn on Windows. FYI, I do know how to do this by modifying add-on r.out.kml in Linux, but it would be good if i could just do my entire workflow on one platform.
Thanks!
Vishal
Vishal K. Mehta, PhD
Sr Scientist
Stockholm Environment Institute - US
133 D St Suite F
Davis CA 95616
www.sei-us.org
kml is usually more used for vector data.
looking at the header "<img style=“margin-right: 0px;” src=“data:image/png;base64,iVBORw0KGgo”, it seems that r.out.gdal is just writing the binary code for your raster in an image tag in the kml file …
Have you try to transform your raster into vector (http://grass.osgeo.org/grass64/manuals/r.to.vect.html) and then to export the vector to kml ?
Sylvain
2014-07-23 20:26 GMT+02:00 Vishal Mehta <vishalm1975@gmail.com>:
Thanks!
Vishal
Sr Scientist
133 D St Suite F
Davis CA 95616
www.sei-us.org
grass-user mailing list
grass-user@lists.osgeo.org
Sylvain,
I agree with your approach. However, I have run into one difficulty, which is if the raster is very detailed (say, 1-ft Lidar) and the computational region is relatively large (several square kilometers), GRASS has considerable problems with the raster-to-vect conversion. The problem is that each raster pixel is transformed to a polygon, so the result is that there can be millions of polygons which the v.build process embedded within r.to.vect , seems to run out of memory. This happens despite the fact that I am running GRASS on 64-bit Ubuntu Linux with 16 GB RAM
My process is this:
r.to.vect -b input=flood_225.50@teaiii output=flood_225_50 type=area
v.db.addcolumn map=flood_225_50@teaiii columns=“flood_area varchar(12)”
v.db.update map=flood_225_50@teaiii layer=1 column=flood_area value=225_50
v.dissolve input=flood_225_50@teaiii column=flood_area output=flood_225_50_dissolve
v.out.ogr -c --overwrite input=flood_226_50_dissolve@teaiii dsn=flood_226_50.kml format=KML
Over the same computational region, if my grid resolution is 3-meters, I have no problems; with 1-ft (~0.3 meters) grid resolution, I have problems.
Tom
On Fri, Jul 25, 2014 at 3:43 AM, Sylvain Maillard <sylvain.maillard@gmail.com> wrote:
Sylvain
Thanks!
Vishal
Sr Scientist
133 D St Suite F
Davis CA 95616
www.sei-us.org
thanks for your suggestions,
i dont really want to convert raster to vector at the exploratory stage i’m in- was just looking to use in-built tools that converted the raster to a png and wrappend kml around it- which is what r.out.kml did.
however, i have never before used this GUI-based “KML SUPEROVERLAY” format option that appears with v.out.ogr. thats what i’ve been trying and failing - just getting a black box which is correctly georegistered. i have a feeling its to do with the rendering of colors for each thematic class, and that in turn might be to do with the data type…but its just a guess.
Vishal
On Fri, Jul 25, 2014 at 5:30 AM, Thomas Adams <tea3rd@gmail.com> wrote:
Sylvain,
My process is this:
Tom
Scientist
133 D St Suite F
Davis CA 95616
www.sei-us.org
Sylvain
Thanks!
Vishal
Sr Scientist
133 D St Suite F
Davis CA 95616
www.sei-us.org
Vishal,
From what I have experienced and read, I believe there could be a color map issue to sort out — I don’t know how to do that; I saw the same thing when I imported a geoTiff image.
Tom
On Fri, Jul 25, 2014 at 12:09 PM, Vishal Mehta <vishalm1975@gmail.com> wrote:
Vishal
Sylvain,
My process is this:
Tom
Scientist
133 D St Suite F
Davis CA 95616
www.sei-us.org
Sylvain
Thanks!
Vishal
Sr Scientist
133 D St Suite F
Davis CA 95616
www.sei-us.org
Vishal wrote:
I'm trying to classify a LANDSAT8 image. In the process, i'd like to
type=Byte nodata=0
I'm just using the GUI options, Grass7svn on Windows. FYI, I do know
(see http://grasswiki.osgeo.org/wiki/AddOns/GRASS_6#r.out.kml )
The r.out.kml addon module should work with GRASS 6.4 on MS Windows
as far as I can tell. If you want to export as JPEG instead of PNG
you'll need to install the Windows build of the NetPBM programs to
get pnmtojpeg.exe though.
It uses r.out.png which exports as colors not values, so the color
table should be preserved.
It is not ported to python for GRASS 7 yet, but it's a pretty simple
script, so shouldn't be too hard.
regards,
Hamish
