Dear all,
I’m doing wildfire simulations in the Grass. I need to calculate the area of only the wildfire spread from the simulation. For that, I need to take only the wildfire spread as a separate layer. But the drawback is the values of the cells in the spread is different from point to point. But it has a range. As an example, the values of cells inside the spread are ranging from 1-90. The other cells in the map show values more than that.
Can I write a mapcalc command for a range like this to output these cells as one layer?
@Nikos has sent me this mapcalc command and from that, we can take only cells with one value as a layer.
r.mapcalc “category_3 = if(spread_time_observed == 3, 3, null())”
instead of that one value(3) in this can we input a range as above(1-90) and get all those cells with different values as one layer?
Thank You
Best Regards
Kalindu Perera
Am 26. Oktober 2018 06:42:44 MESZ schrieb Kalindu Perera <kkc199408@gmail.com>:
Dear all,
I'm doing wildfire simulations in the Grass. I need to calculate the
area
take
it
that.
cells
as one layer?
r.mapcalc "category_3 = if(spread_time_observed == 3, 3, null())"
above(1-90)
You can use >/< and the && (logical AND) to select all pixels within a range in r.mapcalc.
But you could also use r.reclass or r.recode.
Moritz
Thanks a lot Moritz…!!!
Can you just send me one example command?..I’m not sure I understood it in the way that you explained
Thanks again for the quick reply
Best regards
Kalindu Perera
On Fri, 26 Oct 2018 at 11:46, Moritz Lennert <mlennert@club.worldonline.be> wrote:
Dear all,
area
take
it
that.
cells
as one layer?
above(1-90)
Moritz
Am 26. Oktober 2018 09:08:11 MESZ schrieb Kalindu Perera <kkc199408@gmail.com>:
Thanks a lot Moritz....!!!!!!!!
Can you just send me one example command?..I'm not sure I understood it
in
Please do read the r.mapcalc manual, but here's an example:
r.mapcalc "category_range = if(spread_time_observed >= 1 && spread_time_observed <= 90
, 1, null())"
If there are no values below 1 in spread_time_observed, then this can be simplified to
r.mapcalc "category_range = if(spread_time_observed <= 90
, 1, null())"
The result of each command is a map with pixel values of 1 where the condition is met and null where not.
Moritz
Best regards
Kalindu Perera
>Dear all,
>area
>take
the
But
>it
are
>that.
>cells
>as one layer?
only
>above(1-90)
a
range in r.mapcalc.
Moritz
I got it and I’ll read the mapcalc manual as well.
Thanks again
Best regards
Kalindu Perera
On Fri, 26 Oct 2018 at 13:25, Moritz Lennert <mlennert@club.worldonline.be> wrote:
in
Please do read the r.mapcalc manual, but here’s an example:
r.mapcalc “category_range = if(spread_time_observed >= 1 && spread_time_observed <= 90
, 1, null())”
r.mapcalc “category_range = if(spread_time_observed <= 90
, 1, null())”
Moritz
Best regards
Kalindu Perera
Dear all,
area
take
the
But
it
are
that.
cells
as one layer?
only
above(1-90)
a
range in r.mapcalc.
Moritz
