On Mon, Dec 11, 2006 at 12:08:25PM +0800, we recorded a bogon-computron collision of the <raymond_fu@yahoo.com> flavor, containing:
I followed the procedure from the web site http://geni.ath.cx/grass.html#toc5 to install GRASS 6.1.cvs.
Oh. Sorry, can't help you there. Clearly the binary package that is provided
in that way did not get built with all the right libraries, so you can't
use ogr2ogr to do projection conversions.
You might have to build gdal and ogr from source code, and get hold of a
copy of the proj.4 library (you can get it through cygwin).
Tom Russo <russo@bogodyn.org> wrote: On Mon, Dec 11, 2006 at 10:57:40AM +0800, we recorded a bogon-computron collision of the flavor, containing:
> hi,
> I have try your suggestion, but it return the following erors:
> GRASS 6.1.cvs(spearfish60):~>ogr2ogr -srs EPSG:4269 -t_srs EPSG:26713 tgr46081lkA_UTM13_nad27.shp tgr46081lkA.shp
> ERROR 6: Unable to load PROJ.4 library (libproj.so), creation of OGRCoordinateTransfromation failed.
> Failed to create coordinate transformation between the following coordinate systems. This may be because they are not transformable, or because projection services (PROJ.4 DLL/.so) could not be loaded.
> Segmentation fault (core dumped)
Sounds like your gdal installation is missing the proj.4 library, so it can't
do this sort of conversion.
How did you install gdal?
> Tom Russo wrote:
> On Fri, Dec 08, 2006 at 05:07:49PM +0800, we recorded a bogon-computron collision of the flavor, containing:
> > By the way when I try to import ESRI Shape files(TIGER2000) by the fellowing command ogr2ogr -s_srs "+init=epsg:4269" -t_srs "+init=epsg:26713" tgr46081lKA_UTM13_nad27.shp tgr46081lkA.shp, it returns "Failed to process SRS definition: +init=epsg:4269. Do I need install anything additional plugin to make it work?
> Try instead:
> ogr2ogr -s_srs EPSG:4269 -t_srs EPSG:26713
Tom Russo KM5VY SAR502 DM64ux http://www.swcp.com/~russo/
Tijeras, NM QRPL#1592 K2#398 SOC#236 AHTB#1 http://kevan.org/brain.cgi?DDTNM
"And, isn't sanity really just a one-trick pony anyway? I mean all you get is
one trick, rational thinking, but when you're good and crazy, oooh, oooh,
oooh, the sky is the limit!" --- The Tick
Send instant messages to your online friends http://uk.messenger.yahoo.com
