[GRASS-user] file .img and Interrupted Goode Homolosine
Hy everyone.
Two problems:
1) I can not import a file erdas why is not supported.
gdalinfo image.img
ERROR 4: `image.img' not recognised as a supported file format.
gdalinfo failed - unable to open 'image.img'.
2) Projection: Interrupted Goode Homolosine
I could not find the EPSG code, and then I did not create the
location...however, I found the following parameters (but I do not know if
they are correct
-s_srs '+proj=goode +ellps=sphere +towgs84=0,0,0 +lon_0=100w
+x_0=-11119487.43'
Grass 6.4.0
Thanks for any advice
Gabriele
View this message in context: http://osgeo-org.1803224.n2.nabble.com/file-img-and-Interrupted-Goode-Homolosine-tp5778028p5778028.html
2010/11/26 Gabriele N. <gis.gn@libero.it>:
gdalinfo image.img
strange, this formats seems to be supported by GDAL [1].
Martin
[1] http://gdal.osgeo.org/frmt_hfa.html
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
Hi Martin.
Yes, strange ... I tried also with QGIS, and obviously does not work ... : /
This file is strange:) .. also because I can not understand how to create
the location with the projection Interrupted Goode Homolosine...boooh
Gabriele
View this message in context: http://osgeo-org.1803224.n2.nabble.com/file-img-and-Interrupted-Goode-Homolosine-tp5778028p5778080.html
