I was wondering if there are any plans to enable filling of 2D polygons in
NVIZ.
I'm using GRASS 7 but it appears that this feature currently isn't
available.
My workaround is summarised below, but perhaps someone could suggest a
simpler approach. Overlaying a rasterised vector derived simply from
v.to.rast does not give a good display in NVIZ given the topography of the
base DEM layer, hence the method below which extracts DN values from the
DEM.
Summary:
convert 2D polygon to raster (v.to.rast)
create mask from latter raster
add mask (r.mask) and create new layer using r.mapcalc extracting cell
values from DEM: if( dem,dem,0 )
set colour of new raster using r.colors
in NVIZ set Z position of new layer above DEM (e.g., 100)
