[GRASS-user] flow accumulation values
I noticed something today that I don’t understand.
When I run r.watershed and calculate the flow accumulation raster, I expect that along each stream, in the direction of flow, accumulation values will always be higher from one cell to the next. But I see this is not the case. Sometimes, along a stream, the accumulation will drop for one cell, then “jump up” again a few cells downstream.
See the attached image. The green squares are clipped from a flow accum grid. And the numbers are flow accum values. The arrow is general flow direction, and the circles show examples of a sudden drop in flow accum.
I’m aware of the “edge of map” behavior where out of region accum gets a negative value. That’s not the issue here, since the sample in the attached image is from right in the center of the region, no off map flow is involved.
This problem surfaced in a script I’ve prepared to calculate total flow accumulation for each stream reach. After running the addon r.stream.order I add columns to the streams vector map for X-Y of the end points and total flow for each reach, then I use v.what.rast to get the flow accum at each stream reach end-point. But the values I’m getting are strange. Sometimes a downstream reach shows lower total accum than the previous, upstream segment.
Maybe someone can shed some light?
Micha
(attachments)
Is this MFD or SFD? If MFD, flow may split and re-join.
I also noticed that r.stream.extract finds different flow-paths than r.watershed, which complicates comparisons between the two. The work-around for this is to use a mask to force r.stream.extract to find the flow-path you want.
  -k.
On 2016-08-25 at 13:35, Micha Silver <micha@arava.co.il> wrote:
I noticed something today that I don't understand. When I run
cell, then "jump up" again a few cells downstream.
in flow accum.
I'm aware of the "edge of map" behavior where out of region accum gets
a negative value. That's not the issue here, since the sample in the
flow is involved.
This problem surfaced in a script I've prepared to calculate total
get the flow accum at each stream reach end-point. But the values I'm
Thanks, Micha
The default for r.watershed is MFD. I didn’t change that. I didn’t see any splits in the flow path in the sections that I checked. And I didn’t run r.stream.extract, only r.stream.order
Micha
Exactly. With MFD, flow may be distributed to several downstream cells
and the accumulation value can drop when following the extracted path.
This is is most prominent when a river flows into an ocean. Paths,
however, follow Horton's stream network logic and can not split, only
join.
r.stream.extract is the preferred stream extraction tool.
Markus M
  -k.
in flow accum.
flow is involved.
Thanks, Micha
grass-user mailing list
grass-user@lists.osgeo.org
Hi Markus
join.
So what would be the correct way to get total flow accumulation for each stream segment?
Do I have to revert to running r.watershed with the SFD flag?
OK, but a flow accum raster is required for running r.stream.order (which outputs flow_accum) and AFAIK, the only way to get a flow_accum raster is with r.watershed.
Best,
Micha
BTW, I’m not the only one who has encountered this:
http://gis.stackexchange.com/questions/201118/how-to-obtain-accumulation-map-from-r-stream-extract
On Fri, Aug 26, 2016 at 9:41 AM, Micha Silver <micha@arava.co.il> wrote:
Hi Markus
------ Original Message ------ Subject: Re: [GRASS-user] flow accumulation
values Date: Thu, 25 Aug 2016 19:54:59 +0200 To: Ken Mankoff, Micha Silver,
Grass-user From: Markus Metz
join.
stream segment?
Probably yes. For MFD, streams can be more than one cell wide, and you
would need to draw a cross-section at the beginning and end of each
stream segment, then sum up all stream cells for each cross-section.
you want.
with r.watershed.
Correct. Extracting a stream network needs flow accumulation and
elevation as input. Thus the workflow would be 1) r.watershed to get
flow accumulation, 2) r.stream.extract to get the stream network, 3)
r.stream.order.
Markus M
Best,
Micha
Markus M
  -k.
in flow accum.
flow is involved.
Thanks, Micha
you want.
with r.watershed.
BTW, I'm not the only one who has encountered this:
The main purpose of r.stream.extract is to extract a stream network
from any flow accumulation map and elevation map. The flow
accumulation map can be produced with any other tool that is able to
accumulate flow, and that tool does not need to be a GRASS module,
e.g. TAUDEM output is also fine. Further on, any flow accumulation can
be further processed before being used as input for r.stream.extract.
For example, valleys identified by some curvature analysis could be
enhanced.
r.stream.extract can also work with only elevation as input. In this
case flow accumulation is done internally similar to r.watershed. If
you need flow accumulation, it must be calculated first and then used
Markus M
Best,
Micha
I’ve changed my script to use the flags “-a -s” in r.watershed so that Single Flow Direction is used, and flow out of the region is a positive value. Works fine now.
On 31/08/2016 23:33, Markus Metz wrote:
On Fri, Aug 26, 2016 at 9:41 AM, Micha Silver [<micha@arava.co.il>](mailto:micha@arava.co.il) wrote:
Hi Markus
On Thu, Aug 25, 2016 at 4:07 PM, Ken Mankoff [<mankoff@gmail.com>](mailto:mankoff@gmail.com) wrote:
join.
stream segment?
Micha Silver
Arava Drainage Authority
+972-523-665918
Hi Markus
join.
stream segment?
I've changed my script to use the flags "-a -s" in r.watershed so that
Testing SFD and MFD flow accumulation as input for r.stream.extract
and r.stream.order showed that using MFD flow accumulation is fine and
provides reasonable results. For high-resolution DEMs, e.g. 1m LiDAR,
SFD-based results are IMHO unrealistic.
Instead of using flow accumulation at each stream reach end point, you
could also use basin sizes for each stream reach outlet determined
with r.water.outlet or r.stream.basins.
Markus M
