I'm trying to use g.extension to install some add-ons (one of which I recently contributed), but the download fails at some times/on some machines. Just today, I was able to download a particular extension on my Mac, but not on my Linux machine, though bother machines are on the same network. Yesterday, I was unable to download the same extension on my Mac. Here is a typical error:
so g.extension was working for you? is it GRASS 6.4.2? we've
been looking for feedback on that; which way of calling
g.extension? from the Terminal command line or from the wxGUI
menu? see https://trac.osgeo.org/grass/ticket/854
Hi, yes it was a known problem yesterday with the server,
MarkusN restarted Apache, hopefully it helps. If not we may
need to reboot it.
I also frequently experience long delays loading the GRASS
homepage (http://grass.osgeo.org) in a web browser.
Has anyone else experienced network connectivity problems to
machines on the osgeo.org domain?
Unfortunately the osgeo servers are a little bit streched
these days, a victim of their own sucess. For me 0700 GMT +/-
1 hour is often bad, so if it is slow then I just go do
something else for a while and try again later.
Yesterday was unusual though, I have for the first time seen
temporary "unable to connect to server" in the last week or
two, but usually it isn't that bad.
Well it worked in that it could download the code from SVN. The compile fails utterly on OS X, similar to the problems described in the ticket.
repository or no network connection or another problem
need to reboot it.
I continue to have this problem today.
