[GRASS-user] gdal and gdalconst modules?
Hello everybody!
I have a little problem with the raster elaboration.
I found a useful module at cpan.perl.org, which is Geo::Raster.
I saw that the prerequisites are the "libral" library, the Statistics::Details module and the gdal and gdalconst modules.
I installed the library and the Statistic module without problems. Then I installed the Geo::GDAL module form cpan and I tried to install Geo::Raster.
The error message that was prompted was:
>Following required modules are missing: gdalconst gdal.
I tried to install gdal modules using apt-get and, after getting another error, from sources available from www.gdal.org/dl.
Everything worked fine, but, when I tried again to install Geo::Raster, the error message was the same.
What can I do??
My operative system is Debian 3.1 unstable, and everything, except for "libral" and "gdal" was installed with apt-get.
Looking forward to your reply,
Stefano
stefano wrote:
Hello everybody!
What can I do??
Stefano,
I think the key is to configure GDAL with the --with-perl flag then do the
"make" and "make install". By default I don't believe the perl components
will be built.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam@pobox.com
light and sound - activate the windows | http://pobox.com/~warmerdam
and watch the world go round - Rush | President OSGF, http://osgeo.org
Frank Warmerdam wrote:
stefano wrote:
Hello everybody!
What can I do??
Stefano,
will be built.
Best regards,
Yes, I built the perl modules and everything worked fine!
Thanks!
Stefano
