[GRASS-user] gdal_translate too many command options
Dear community
The main aim is to produce a mask of a raster file with data > 0
Code:
r.mask raster=ch_apple_presence_total_pollinator_abundance_spring maskcats=“0.01 thru 1”
ERROR: The raster map <ch_apple_presence_total_pollinator_abundance_spring> must be integer (CELL type) in order to use the ‘maskcats’ parameter
Because of the error I followed the help here:
https://gis.stackexchange.com/questions/197145/error-in-r-thin-qgis-grass-input-raster-must-be-of-type-cell
However, wen running the code suggested with gdal_translate, I got an error
gdal_translate -co "ch_apple_presence_total_pollinator_abundance_spring " ch_apple_presence_total_pollinator_abundance_spring.tif bit_ ch_apple_presence_total_pollinator_abundance_spring.tif
r.null map=ch_apple_presence_total_pollinator_abundance_spring setnull=1
gdal_translate -co ch_apple_presence_total_pollinator_abundance_spring ch_apple_presence_total_pollinator_abundance_spring.tif bit_ ch_apple_presence_total_pollinator_abundance_spring.tif
ERROR 6: Too many command options
‘ch_apple_presence_total_pollinator_abundance_spring.tif’
Usage: gdal_translate [–help] [–help-general] [–long-
usage]
[-ot {Byte/Int8/Int16/UInt16/UInt32/Int32/UInt64/Int6
4/Float32/Float64/
CInt16/CInt32/CFloat32/CFloat64}] [-strict]
[-if ]… [-of ]
[-b ] [-mask ] [-expand {gray|rgb|rgba}]
[-outsize [%]|0 [%]|0] [-tr
[-ovr |AUTO|AUTO-|NONE]
[-r
{nearest,bilinear,cubic,cubicspline,lanczos,average,mode}]
[-unscale] [-scale[_bn] [<src_min> <src_max>
[<dst_min> <dst_max>]]]… [-exponent[_bn] <exp_val>]…
[-srcwin ] [-epo] [-eco]
[-projwin ] [-projwin_srs
<srs_def>]
[-a_srs <srs_def>] [-a_coord_epoch ]
[-a_ullr ] [-a_nodata ]
[-a_gt ]
[-a_scale ] [-a_offset ]
[-nogcp] [-gcp
|-colorinterp{_bn}
{red|green|blue|alpha|gray|undefined}]
|-colorinterp
{red|green|blue|alpha|gray|undefined},…]
[-mo =]… [-q] [-sds]
[-co =]… [-stats] [-norat] [-noxmp]
[-oo =]…
<src_dataset> <dst_dataset>
Thanks a lot
Sibylle
On 30/05/2024 15:58, sibylle via grass-user wrote:
Dear community
Maybe using r.mapcalc to create the raster mask would be more appropriate:
r.mapcalc “MASK = if(ch_apple_presence_total_pollinator_abundance_spring > 0, 1, null())”
After that command completes, all further raster modules will work only on non-null cells in the MASK raster. You should see the message “[Raster MASK present]”
To remove it, you would do: r.mask -r
HTH, Micha
Code:
usage]
4/Float32/Float64/
[-if ]… [-of ]
[-r
<srs_def>]
[-a_gt ]
[-nogcp] [-gcp
|-colorinterp{_bn}
|-colorinterp
[-oo =]…
Thanks a lot
Sibylle
grass-user mailing list
[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
[https://lists.osgeo.org/mailman/listinfo/grass-user](https://lists.osgeo.org/mailman/listinfo/grass-user)
Micha Silver
Ben Gurion Univ.
Sde Boker, Remote Sensing Lab
cell: +972-523-665918
