Greetings Markus
(I changed the subject since it’s happening in 6.4.1)
There is no error. It just freezes. It creates the bands and georrectigfies but the panels, windows are freezed.
On Fri, Apr 29, 2011 at 1:11 PM, Monica Buescu
<monicabuescu1985@gmail.com> wrote:
Greetings Markus
(I changed the subject since it's happening in 6.4.1)
Do you see a grey box saying
"Rectifying images, please wait..."
on top of the window with the GCPs and two map displays?
hello all,
Is there a quick way to tell which version of GRASS a raster was created by?
I am having issues with consistency of output from r.mfilter between GRASS 6.4 and GRASS 7 (which I run in parallel on a 64bit Ubuntu 10.4 system) and need to be certain which version I used to create which output.
Many thanks,
Rebecca
No.
6.x has r.mfilter (integer) and r.mfilter.fp (floating point). 7.0's
r.mfilter is the floating-point version.
If the data contains nulls, the integer version will convert them to
zeros, while the floating-point version will exclude them from the
calculation.
Hi Glynn,
Thanks fro your reply that’s really helpful!
Is there any chance that we could update the manual to link to r.mfilter.fp from the r.mfilter page (thwe reverse link is already there)?
Thanks again,
Rebecca
To: Rebecca Bennett rabennett@ymail.com
Cc: GRASS user list grass-user@lists.osgeo.org
Sent: Mon, 2 May, 2011 17:31:18
Subject: Re: [GRASS-user] Grass version
No.
6.x has r.mfilter (integer) and r.mfilter.fp (floating point). 7.0’s
calculation.
On Mon, May 2, 2011 at 7:16 PM, Rebecca Bennett <rabennett@ymail.com> wrote:
Hi Glynn,
Thanks fro your reply that's really helpful!Is there any chance that we could update the manual to link to r.mfilter.fp
Sure, done.
As soon as the SVN repo is functional again (the next day(s) I hope), I'll
commit. Will be for 6.4.2 and later then.
