Hi all
I am running Grass 6.2.3 under Cygwin on a laptop with 512MB RAM and Windows XP. I can run Grass from the command line, but when I try to load the gis manager with “gis.m &”, it appears for a split second and than exits (see screendump below).
Does anyone have an idea why it is doing this?
Thanks
Brendon Wolff-Piggott
/ integrated geodata solutions /
/ pretoria, republic of south africa /
GRASS 6.2.3 (test):~ > gis.m &
[1] 2440
GRASS 6.2.3 (test):~ > child process exited abnormally
Error in startup script: can’t read “monitor_zooms(1,1,n)”: no such variable
while executing
“lappend region $monitor_zooms($mon,1,$attr)”
(procedure “MapCanvas::currentzoom” line 13)
invoked from within
“MapCanvas::currentzoom $mon”
(procedure “MapCanvas::coordconv” line 23)
invoked from within
“MapCanvas::coordconv $mon”
(procedure “MapCanvas::create” line 68)
invoked from within
“MapCanvas::create”
(procedure “Gm::startmon” line 11)
invoked from within
“Gm::startmon”
(procedure “Gm::create” line 69)
invoked from within
“Gm::create”
(procedure “main” line 30)
invoked from within
“main $argc $argv”
(file “/usr/local/grass-6.2.3/etc/gm/gm.tcl” line 521)
