Hello,
anyone has expierences with gpsbabel?
I try to import data from a garmin etrex gps
I use this command:
gpsbabel -t D9 -i garmin -f /dev/ttyUSB0 -o garmin_txt,grid=ddd,prec=6 -F trackpoints.dat
cause I read in http://www.gpsbabel.org/htmldoc-development/fmt_garmin_txt.html
that one can specify a grid-parameter:
grid option
Write position using this grid..
This value specifies the grid to be used on write.
Table 3.1. Grid values for garmin_txt
# idx short file-header sample
0 ddd Lat/Lon hddd.ddddd S26.25333 E27.92333
1 dmm Lat/Lon hddd°mm.mm N33 56.539 W118 24.471
unfortunately it doesnt work.
the gpsbabel --help tells me
garmin_txt Garmin MapSource - txt (tab delimited)
date Read/Write date format (i.e. yyyy/mm/dd)
datum GPS datum (def. WGS 84)
dist Distance unit [m=metric, s=statute]
prec Precision of coordinates
temp Temperature unit [c=Celsius,
NO GRID-PARAMETER!!! :o(
so whatever grid-parameter I set i get a file-header like
Grid Lat/Lon hddd mm.mmm'
Datum WGS 84
I need the grid #idx=1 (ddd) to sort and filter the points before I import them to GRASS. I tried different settings but I got everytime the dmm-format.
Finally I want to project the data in Gauss-Krueger-Projection (Transversal-Mercator).
I know that GRASS contains v.in.gpsbabel and v.in.garmin. Its very nice that I get the data immediatley in Gauss-Krueger-coordinates. But using this tools it doesn't work to import altitude-data and other informations as well.
Is there a posibility to get Gauss-Krueger-Data just by using gpsbabel?
Between the ++++ I pasted the outputs of different attempts of v.in.garmin and v.in.gpsbael. Jump to the END if you want to save time!!!
v.in.garmin port=/dev/ttyUSB0 -t -p out=vingarmin_gpstrans_tracks
GPStrans (ASCII) - Version 0.39
Copyright (c) 1995 by Carsten Tschach (tschach@zedat.fu-berlin.de)
Linux/KKJ mods by Janne Sinkkonen <janne@iki.fi> (1996)
Copyright (c) 2000 German Grid by Andreas Lange <andreas.lange@rhein-main.de>
Copyright (c) 1998,2000 Mayko-mXmap mods by Matthias Kattanek <mattes@ugraf.com>
Copyright (c) 2001 Development by Joao Seabra-CT2GNL <seabra@ci.AAC.uc.pt>
Receiving Tracks...
ERROR: Only DDD coordinates currently supported. [DMS]
v.in.garmin port=/dev/ttyUSB0 -t -p -u out=vingarmin_gardump_tracks
Receiving Tracks...
gardump: unknown track packet type: 0
Attempting waypoint projection transform with cs2cs...
Importing Track as points...
Building topology for vector map <vingarmin_gardump_tracks>...
6792 primitives registered
Building areas: 100%
---> with v.out.ascii I get this format:
4416848.824221|5359764.2067414|25 #id=25
v.in.garmin port=/dev/ttyUSB0 -t -p -u -z out=vingarmin_gardump_tracks_z
Receiving Tracks...
--> WARNING: No altitude data found, creating 2D vector map <--
and so on...
v.in.gpsbabel in=/dev/ttyUSB0 -t -p output=vingpsbabel_tracks
Loading Tracks as points from </dev/ttyUSB0>...
Building topology for vector map <vingpsbabel_tracks>...
4416846.9562442|5359757.9513647|26 #id=26
v.in.gpsbabel in=/dev/ttyUSB0 -t -p output=vingpsbabel_tracks_ddd for=garmin_txt,grid=ddd
'grid=ddd' is an unknown option to garmin_txt.
Quit
Does not do anything...
END
The solution I get for me is to connect the output of v.out.ascii and also the output of gpsbabel (both have 6792 points) paste them together, use awk and so on and import it enentually with v.in.ascii -z
But this cannot be the final solution... can it???
Philipp
PS:
Versions:
GPSBabel Version: 1.3.2
eTrex.VistaCx.Software.Version.2.50.
Unit: eTrex VistaCx Software Version 2.50
Version: 2.50Rx
GRASS 6.3 svn
debian etch
PS:I post this mail also to the gpsbabel-misc-list
