[GRASS-user] Grass 6.1 - error installing rpm
hi grass-friends,
i´ve downloaded the rpm´s for the new release of grass 6.1.
the install of the rpm´s for proj4, geos, and gdal was o.k.
installing the GRASS 6.1-rpm´s i got following message:
"Installing grass-6.1.0-1suse10.0.i586 [Local packages]. There are no installable providers of libmysqlclient.so.14 for grass-6.1.0-1suse10.0.i586 [Local packages]."
in the spec-file i saw that the rpm for grass was build with the mysql-option.
any hints for solving the rpm-dependency-problem?
suse 10.1. on my computer.
thanks a lot for the hard work for GRASS 6.1.
greetings
helli
www.alectoria.at
______________________________________________________________
Verschicken Sie romantische, coole und witzige Bilder per SMS!
Jetzt bei WEB.DE FreeMail: http://f.web.de/?mc=021193
On Sun, Aug 13, 2006 at 08:49:53PM +0200, Helmut Kudrnovsky wrote:
hi grass-friends,
i?ve downloaded the rpm?s for the new release of grass 6.1.
the install of the rpm?s for proj4, geos, and gdal was o.k.
installing the GRASS 6.1-rpm?s i got following message:
greetings
Hi helli,
apparently I forgot to define
Requires: mysql
in the spec file. Can you install the mysql RPM and try again?
Then it should hopefully work.
You may contact me through personal email to work that out.
> hi grass-friends,
> greetings
Hi helli,
Requires: mysql
Checking again, it seems that
mysql-shared
would be sufficient. I cannot login to our Suse PC right now, so
I cannot check.
