Dominik wrote:
Since I assume that both GUIs use the v.digit programm,
No, they are completely different. The v.digit version available
in Tcl/Tk GIS.m is C + Tcl/Tk written by Radim & Glynn.
The Vdigit that is used in the wxPython GUI is C++ + wxPython
written by Martin.
You might also try the QGIS vector digitizer to edit the GRASS
data layers. Several posters seem to enjoy that route.
I also assume that the problem with the old Tcl/Tk GUI, which
is described in my first post, is related to it, right?
probably not.
[problem was:]
When I try to do the same within the Tcl/Tk GUI I can create
vectors within the specified vector map, but since I want to
digitize a raster file,this raster file isn't loaded as a
background, even if the log window says so. I even tried to
type the command by hand,but the result was the same, no
background map!
steps used?
for me on Linux it works:
New map
new vector map name= test_map1
Display commands = d.rast elevation.dem
whole command looks like:
v.digit -n map=test_map1 {bgcmd=d.rast elevation.dem}
Hamish
