[GRASS-user] Grass 6.4.3-5.52 installation on Opensuse 13.1
I've run into a problem installing GRASS 6.4.3 binary onto an Opensuse
13.1 linux system. The installation proceudre reports that
libgeos-3.4.2 is needed and "nothing provides" it. Installing a copy
of libgeos-3.4.2 encounters a similar error stating that a GDAL version
is "not provided," which is wrong because the GDAL version called
for is already installed on the system.
Presumably there's some configuration problem with the combination of
GRASS and Opensuse. If anyone has encountered this and solved the
problem, I would appreciate information on what I am doing wrong.
JWDougherty
Hi
I’ve installed GRAS 6.4.3-5.41 from the rpm repository:
http://download.opensuse.org/repositories/Application:/Geo/openSUSE_13.1
with no problems
JM Garijo
El Miércoles 15 de enero de 2014 6:49, jwd jwd@surewest.net escribió:
I’ve run into a problem installing GRASS 6.4.3 binary onto an Opensuse
libgeos-3.4.2 is needed and “nothing provides” it. Installing a copy
is “not provided,” which is wrong because the GDAL version called
Presumably there’s some configuration problem with the combination of
JWDougherty
grass-user mailing list
grass-user@lists.osgeo.org
