I've taken the plunge and installed Grass-7.0 for a look. Attempting a v.distance, I'm getting a feature type error. Here is v.info on the "to" map:
GRASS 7.0.svn (Australia):~ > v.info MapB -t
nodes=0
points=5113
lines=0
boundaries=0
centroids=0
areas=0
islands=0
primitives=5113
map3d=0
Here's what happens to v.distance:
GRASS 7.0.svn (Australia):~ > v.distance from=MapA from_type=centroid to=MapB to_type=point upload=dist column=Dist
ERROR: No features of selected type found in <MapB@Copy>
Since the maps were copied over from an 6.4 install, I have run v.build on all maps.
Environment is Debian (a new install in a virtual machine).
Richard C
On Thu, Oct 18, 2012 at 4:49 AM, Richard Chirgwin
<rchirgwin@ozemail.com.au> wrote:
map:
nodes=0
points=5113
lines=0
boundaries=0
centroids=0
areas=0
islands=0
primitives=5113
map3d=0
Oops, fixed in r53459.
Markus M
all maps.
Richard C
grass-user mailing list
grass-user@lists.osgeo.org
map:
nodes=0
points=5113
lines=0
boundaries=0
centroids=0
areas=0
islands=0
primitives=5113
map3d=0
Markus - thanks, will check it out.
Richard
Markus M
all maps.
Richard C
