[GRASS-user] GRASS 7.2.1 for centos 7 from copr/neteler repo
Dear all,
I am trying to install GRASS 7.2.1 using the repository neteler-grass72 on a machine running centos 7 [Linux version 3.10.0-514.26.2.el7.x86_64 (builder@kbuilder.dev.centos.org) (gcc version 4.8.5 20150623 (Red Hat 4.8.5-11) (GCC) )]
I get the following errors:
Error: Package: grass-libs-7.2.1-6.fc26.x86_64 (neteler-grass72)
Requires: libproj.so.12()(64bit)
Requires: libm.so.6(GLIBC_2.23)(64bit)
Requires: libgdal.so.20()(64bit)
Requires: libcrypto.so.1.1()(64bit)
Requires: libpng16.so.16()(64bit)
Requires: libpng16.so.16(PNG16_0)(64bit)
Requires: libgeos-3.6.1.so()(64bit)
Requires: libssl.so.1.1()(64bit)
As far as I can see it requires versions of the libraries that are not readily available from centos 7 repositories (including epel).
I could compile grass 7.2.1 from source without problems, but I would prefer to use the repository if at all possible.
What am I missing ? Do I need to compile the dependencies before in order to have the right versions? Are there any repositories where the rmps could be found?
Thanks a lot in advance
Laura
Hi Laura,
On Fri, Jul 21, 2017 at 12:51 PM, Laura Poggio <laura.poggio@gmail.com> wrote:
Dear all,
This one:
https://copr.fedorainfracloud.org/coprs/neteler/grass72/
4.8.5-11) (GCC) )]
I have compiled the version in July on COPR.
https://copr.fedorainfracloud.org/coprs/neteler/grass72/builds/
Did you install beforehand
yum install epel-release
yum install gdal gdal-python gdal-devel
found?
Those two above should deliver the needed proj and gdal RPMs.
Best
Markus Neteler, PhD
http://www.mundialis.de - free data with free software
http://grass.osgeo.org
http://courses.neteler.org/blog
Dear Markus,
I followed the instruction in https://copr.fedorainfracloud.org/coprs/neteler/grass72/. I still get the same errors I posted above. The latest gdal I can install from epel repo is version 1.11.4. If it help, the centos version I am using is the latest available image on google cloud compute (CentOS, CentOS, 7, x86_64 built on 2017-07-19).
Thanks a lot
Laura
On 8 August 2017 at 23:43, Markus Neteler <neteler@osgeo.org> wrote:
Hi Laura,
Dear all,
This one:
4.8.5-11) (GCC) )]
found?
Best
Markus Neteler, PhD
Dear Laura,
On Wed, Aug 9, 2017 at 9:54 AM, Laura Poggio <laura.poggio@gmail.com> wrote:
Dear Markus,
2017-07-19).
The other day I updated to 7.2.2. Does this work for you?
