Running PG connection on grass70 works for me as well.
Wild guess:
1.) Are the maps stored in Schemas? (see $INPATH below)
2.) Have you tested the change/removing of quotations? (see codeexample below)
My (tested) code in BASH:
GSCHEMA=grass_2015
INPATH="PG:dbname=$DB_NAME active_schema=$ISCHEMA"
db.connect driver=pg database=psql_local schema=$GSCHEMA #no quotations here"
db.connect -p
v.in.ogr dsn="$INPATH" out=pt layer="xy" --overwrite #I use quotations here
On Sep 2, 2016 6:45 PM, "Nikos Alexandris" [<nik@nikosalexandris.net>](mailto:nik@nikosalexandris.net) wrote:
Patrick
