There were a bunch of other paths I had to fix as well. But, after doing the following, it does now run with the gui:
$ install_name_tool -change @loader_path/…/…/…/…/libwx_osx_cocoau-3.0.0.2.0.dylib /Applications/GRASS-7.3.app/Contents/MacOS/lib/libwx_osx_cocoau-3.0.0.2.0.dylib /Applications/GRASS-7.3.app/Contents/MacOS/etc/python/wx/core.so
$ install_name_tool -change @loader_path/…/…/…/…/libwx_osx_cocoau-3.0.0.2.0.dylib /Applications/GRASS-7.3.app/Contents/MacOS/lib/libwx_osx_cocoau-3.0.0.2.0.dylib /Applications/GRASS-7.3.app/Contents/MacOS/etc/python/wx/gdi.so
$ install_name_tool -change @loader_path/…/…/…/…/libwx_osx_cocoau-3.0.0.2.0.dylib /Applications/GRASS-7.3.app/Contents/MacOS/lib/libwx_osx_cocoau-3.0.0.2.0.dylib /Applications/GRASS-7.3.app/Contents/MacOS/etc/python/wx/windows.so
$ install_name_tool -change @loader_path/…/…/…/…/libwx_osx_cocoau-3.0.0.2.0.dylib /Applications/GRASS-7.3.app/Contents/MacOS/lib/libwx_osx_cocoau-3.0.0.2.0.dylib /Applications/GRASS-7.3.app/Contents/MacOS/etc/python/wx/controls.so
$ install_name_tool -change @loader_path/…/…/…/…/libwx_osx_cocoau-3.0.0.2.0.dylib /Applications/GRASS-7.3.app/Contents/MacOS/lib/libwx_osx_cocoau-3.0.0.2.0.dylib /Applications/GRASS-7.3.app/Contents/MacOS/etc/python/wx/misc.so
$ install_name_tool -change @loader_path/…/…/…/…/libwx_osx_cocoau-3.0.0.2.0.dylib /Applications/GRASS-7.3.app/Contents/MacOS/lib/libwx_osx_cocoau-3.0.0.2.0.dylib /Applications/GRASS-7.3.app/Contents/MacOS/etc/python/wx/_combo.so
$ install_name_tool -change @loader_path/…/…/…/…/libwx_osx_cocoau-3.0.0.2.0.dylib /Applications/GRASS-7.3.app/Contents/MacOS/lib/libwx_osx_cocoau-3.0.0.2.0.dylib /Applications/GRASS-7.3.app/Contents/MacOS/etc/python/wx/_aui.so
$ install_name_tool -change @loader_path/…/…/…/…/libwx_osx_cocoau-3.0.0.2.0.dylib /Applications/GRASS-7.3.app/Contents/MacOS/lib/libwx_osx_cocoau-3.0.0.2.0.dylib /Applications/GRASS-7.3.app/Contents/MacOS/etc/python/wx/_html.so
$ install_name_tool -change @loader_path/…/…/…/…/libwx_osx_cocoau-3.0.0.2.0.dylib /Applications/GRASS-7.3.app/Contents/MacOS/lib/libwx_osx_cocoau-3.0.0.2.0.dylib /Applications/GRASS-7.3.app/Contents/MacOS/etc/python/wx/_gizmos.so
$ install_name_tool -change @loader_path/…/…/…/…/libwx_osx_cocoau-3.0.0.2.0.dylib /Applications/GRASS-7.3.app/Contents/MacOS/lib/libwx_osx_cocoau-3.0.0.2.0.dylib /Applications/GRASS-7.3.app/Contents/MacOS/etc/python/wx/_stc.so
$ install_name_tool -change @loader_path/…/…/…/…/libwx_osx_cocoau-3.0.0.2.0.dylib /Applications/GRASS-7.3.app/Contents/MacOS/lib/libwx_osx_cocoau-3.0.0.2.0.dylib /Applications/GRASS-7.3.app/Contents/MacOS/etc/python/wx/_wizard.so
In addition to the prior fix:
install_name_tool -change /usr/local/lib/libintl.8.dylib /Applications/GRASS-7.3.app/Contents/MacOS/lib/libintl.8.dylib /Applications/GRASS-7.3.app/Contents/MacOS/lib/libgrass_gis.7.3.svn
I opened and displayed a single mapset, so I haven’t tested most other features, but it does now seem to run with SIP enabled. So, it looks like you just missed the correct paths in the build to a few dynamic libraries that you have correctly included.
Thanks much for getting this going.
– Adam
From: grass-user <grass-user-bounces@lists.osgeo.org> on behalf of Adam Dershowitz <adershowitz@exponent.com>
Date: Thursday, June 2, 2016 at 10:06 AM
To: Michael Barton <Michael.Barton@asu.edu>, GRASS developers list <grass-dev@lists.osgeo.org>, grass-user grass-user <grass-user@lists.osgeo.org>
Subject: Re: [GRASS-user] GRASS for Mac 64bit, wxPython 3, maybe fix for SIP problem - please test
And, I tried fixing that one path like this:
install_name_tool -change /usr/local/lib/libintl.8.dylib /Applications/GRASS-7.3.app/Contents/MacOS/lib/libintl.8.dylib /Applications/GRASS-7.3.app/Contents/MacOS/lib/libgrass_gis.7.3.svn.dylib
but then I get this dynamic library error:
$ ‘/Applications/GRASS-7.3.app/Contents/MacOS/grass.sh’; exit
Rebuilding Addon HTML manual pages index…
Rebuilding Addon menu…
Python 2.7.10 found.
Cleaning up temporary files…
Starting GRASS GIS…
File “/Applications/GRASS-7.3.app/Contents/MacOS/gui/wxpython/gis_set.py”, line 31, in
from core import globalvar
File “/Applications/GRASS-7.3.app/Contents/MacOS/gui/wxpython/core/globalvar.py”, line 96, in
import wx
File “/Applications/GRASS-7.3.app/Contents/MacOS/etc/python/wx/init.py”, line 45, in
from wx._core import *
File “/Applications/GRASS-7.3.app/Contents/MacOS/etc/python/wx/_core.py”, line 4, in
import core
ImportError: dlopen(/Applications/GRASS-7.3.app/Contents/MacOS/etc/python/wx/core.so, 2): Library not loaded: @loader_path/…/…/…/…/libwx_osx_cocoau-3.0.0.2.0.dylib
Referenced from: /Applications/GRASS-7.3.app/Contents/MacOS/etc/python/wx/core.so
Reason: image not found
ERROR: Error in GUI startup. See messages above (if any) and if necessary, please report this error to the GRASS developers.
On systems with package manager, make sure you have the right GUI package, probably named grass-gui, installed.
To run GRASS GIS in text mode use the -text flag.
Exiting…
logout
Saving session…
…copying shared history…
…saving history…truncating history files…
…completed.
[Process completed]
– Adam
Date: Thursday, June 2, 2016 at 9:54 AM
Looks like you missed a library, or path. I just tried it on 10.11 with SIP enabled, and I get this error:
Starting GRASS GIS…
dyld: Library not loaded: /usr/local/lib/libintl.8.dylib
Referenced from: /Applications/GRASS-7.3.app/Contents/MacOS/lib/libgrass_gis.7.3.svn.dylib
File “/Applications/GRASS-7.3.app/Contents/MacOS/gui/wxpython/core/globalvar.py”, line 29, in
from core.debug import Debug
File “/Applications/GRASS-7.3.app/Contents/MacOS/gui/wxpython/core/debug.py”, line 77, in
Debug = DebugMsg()
File “/Applications/GRASS-7.3.app/Contents/MacOS/gui/wxpython/core/debug.py”, line 39, in init
self.SetLevel()
File “/Applications/GRASS-7.3.app/Contents/MacOS/gui/wxpython/core/debug.py”, line 45, in SetLevel
self.debuglevel = int(grass.gisenv().get(‘WX_DEBUG’, 0))
File “/Applications/GRASS-7.3.app/Contents/MacOS/etc/python/grass/script/core.py”, line 953, in gisenv
s = read_command(“g.gisenv”, flags=‘n’)
File “/Applications/GRASS-7.3.app/Contents/MacOS/etc/python/grass/script/core.py”, line 458, in read_command
process = pipe_command(*args, **kwargs)
File “/Applications/GRASS-7.3.app/Contents/MacOS/etc/python/grass/script/core.py”, line 433, in pipe_command
return start_command(*args, **kwargs)
File “/Applications/GRASS-7.3.app/Contents/MacOS/etc/python/grass/script/core.py”, line 372, in start_command
if debug_level() > 0:
File “/Applications/GRASS-7.3.app/Contents/MacOS/etc/python/grass/script/core.py”, line 1536, in debug_level
_debug_level = int(gisenv().get(‘DEBUG’, 0))
File “/Applications/GRASS-7.3.app/Contents/MacOS/etc/python/grass/script/core.py”, line 461, in read_command
return handle_errors(returncode, stdout, args, kwargs)
File “/Applications/GRASS-7.3.app/Contents/MacOS/etc/python/grass/script/core.py”, line 329, in handle_errors
returncode=returncode)
grass.exceptions.CalledModuleError: Module run None [‘g.gisenv’, ‘-n’] ended with error
Process ended with non-zero return code -5. See errors in the (error) output.
Exiting…
logout
Saving session…
…completed.
– Adam
From: grass-user <grass-user-bounces@lists.osgeo.org> on behalf of Michael Barton <Michael.Barton@asu.edu>
Date: Wednesday, June 1, 2016 at 7:50 PM
To: GRASS developers list <grass-dev@lists.osgeo.org>, grass-user grass-user <grass-user@lists.osgeo.org>
Subject: [GRASS-user] GRASS for Mac 64bit, wxPython 3, maybe fix for SIP problem - please test
I just posted a new binary for GRASS 7.3 built fully 64 bit, with wxPython 3.0.2.0 to the GRASS for Mac site (http://grassmac.wikidot.com)
It turns out the previous “64bit” GRASS binary still ran 32bit Python. I had to hack the python_wrapper.py file, but this one is fully 64bit AFAICT. I also tried some hacks that might be a way to solve the inability to run GRASS on El Capitan with SIP enabled. There are a couple of known bugs in the wxPython 3.x GUI
The most serious is switching to 3D mode and back to 2D mode leaves one of the map display menu buttons corrupted. It seems the only thing you can do is to close the map display and open a new one.
There are also some popup lists (e.g., for switching mapsets) that do not behave as they should. You cannot select an item with a mouse (but you can select with arrow keys and ) unless you hit to destroy part of the control. Then you can use the mouse to click something.
Please let us know if you encounter any other bug or strange behavior.
Also, and importantly if anyone is running El Capitan, it would be great if you could reenable SIP (if you’ve turned it off) and see if this version runs. Of course, maybe I’ve “fixed” it so that it only runs on my system and crashes on everyone else’s.
Enjoy!
Michael
C. Michael Barton
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
