[GRASS-user] GRASS GIS : r.mblend: Data base element error.
I’m using r.mblend within GRASS GIS v7.8.8 on Windows as well as on GRASS GIS v8.2.1 on Linux , attempting to merge higher resolution raster files (30 m) with lower resolution (500m). Everything is running until the print out step “Dropping extra column from far edge” at which point I hit an error: “Database connection not defined for layer 1”. I tried it both on Windows and Linux. I encountered the same error. I even changed the projections of the raster file from UTM to WGS, still it showed the errors.
Below I have attached the Command Output :
(Thu Nov 2 12:46:45 2023)
r.mblend high=N15E073@PERMANENT low=gebco_2023_UTM@PERMANENT
output=blend
[r.mblend] Resampling low resolution raster to higher resolution
[r.mblend] Multiplying low resolution by zero
[r.mblend] Multiplying high resolution by zero
[r.mblend] Computing extent of low resolution
Extracting areas…
Writing areas…
Building topology for vector map tmp_189483@PERMANENT
Registering primitives…
Building areas…
Attaching islands…
Attaching centroids…
r.to.vect complete.
[r.mblend] Computing extent of high resolution
Extracting areas…
Writing areas…
Building topology for vector map tmp_189484@PERMANENT
Building areas…
Attaching islands…
r.to.vect complete.
[r.mblend] Computing area to interpolate
Copying vector features from tmp_189483@PERMANENT
Copying vector features from tmp_189484@PERMANENT
Snapping boundaries with 1e-08 …
Breaking lines…
Removing duplicates…
Cleaning boundaries at nodes…
Merging lines…
Attaching islands…
Building areas…
Attaching islands…
Querying vector map tmp_189483@PERMANENT
Querying vector map tmp_189484@PERMANENT
Writing centroids…
Copying results to final output map…
Building topology for vector map tmp_189485@PERMANENT
Building areas…
Attaching islands…
v.overlay complete.
[r.mblend] Computing buffer around interpolation area
Buffering areas…
Cleaning buffers…
Building parts of topology…
Building topology for vector map tmp_189486@PERMANENT
Snapping boundaries…
Reading features…
Snap vertices Pass 1: select points
Snap vertices Pass 2: assign anchor vertices
Snap vertices Pass 3: snap to assigned points
Breaking polygons…
Breaking polygons (pass 1: select break points)…
Breaking polygons (pass 2: break at selected points)…
Breaking boundaries…
Building areas…
Removing dangles…
Removing bridges…
Attaching islands…
Attaching islands…
Calculating centroids for all areas…
Generating list of boundaries to be deleted…
Deleting boundaries…
Calculating centroids for areas…
Building areas…
Attaching islands…
[r.mblend] Vectorising differences between input rasters
Reading areas…
Writing raster map…
All subsequent raster operations will be limited to the MASK area. Removing or renaming raster map named ‘MASK’ will restore raster operations to normal.
Extracting points…
Building topology for vector map tmp_189488@PERMANENT
r.to.vect complete.
Raster MASK removed
[r.mblend] Computing distance to high resolution raster
Reading raster map N15E073@PERMANENT
Writing output raster maps…
[r.mblend] Rescaling distance to [0,10000] interval
Rescale tmp_189489[0,1453] to tmp_1894810[0,10000]
[r.mblend] Extract points from interpolation area boundary
Building topology for vector map tmp_1894812@PERMANENT
v.to.points complete. 207 points written to output vector map.
[r.mblend] Copying features to layer 1
WARNING: Database connection and attribute tables for concerned layers are not changed
Processing features…
Copying attribute table(s)…
Building topology for vector map tmp_1894811@PERMANENT
v.category complete. 207 features modified.
[r.mblend] Linking attribute table to layer 1
The table <tmp_1894811> is now part of vector map <tmp_1894811> and may be deleted or overwritten by GRASS modules
Select privileges were granted on the table
[r.mblend] Querying distances raster
Column not found in the table <tmp_1894811>. Creating…
Reading features from vector map…
Update vector attributes…
v.what.rast complete. 207 records updated.
[r.mblend] Selecting far edge points (using cut-off percentage)
Extracting features…
Building topology for vector map tmp_1894816@PERMANENT
Writing attributes…
[r.mblend] Dropping extra column from far edge
ERROR: Database connection not defined for layer 1
Region:
{‘projection’: 1, ‘zone’: 43, ‘n’: 1769980.79652272, ‘s’: 1658549.10764584, ‘w’: 284498.79684178, ‘e’: 393033.65992938, ‘nsres’: 30.27212412, ‘ewres’: 30.27471774, ‘rows’: 3681, ‘cols’: 3585, ‘cells’: 13196385}
File “C:\Users\jobthomas97\AppData\Roaming\GRASS7\addons\s
cripts\r.mblend.py”, line 332, in
main()
cripts\r.mblend.py”, line 279, in main
gscript.run_command(
File “C:\Program Files\GRASS GIS
7.8\etc\python\grass\script\core.py”, line 441, in
run_command
return handle_errors(returncode, returncode, args,
kwargs)
7.8\etc\python\grass\script\core.py”, line 342, in
handle_errors
raise CalledModuleError(module=None, code=code,
grass.exceptions.CalledModuleError: Module run None
v.db.dropcolumn map=tmp_1894816 layer=1 columns=along ended
with error
Process ended with non-zero return code 1. See errors in the
(error) output.
WARNING: No data base element files found
WARNING: Table <tmp_1894811> linked to vector map <tmp_1894811> does not exist
(Thu Nov 2 12:47:06 2023) Command finished (20 sec)
Job Thomas.
Hi Job,
looks like something is going wrong creating the attribute table for the interpolation points vector. This is made with v.db.connect at the time of the “Linking attribute table to layer 1” message. Which back-end are you using? The SQLite default? I would ask you to verify whether v.db.connect is working correctly on your system, you can create a new points vector and then test with v.db.select. Another experiment is trying a different back-end. For serious stuff I use Postgres.
If your data are cartographic (UTM) you should stick to the original CRS and not transform to a geographic system. It is also preferable if you use GRASS 8.
Regards.
Luís
Sent with Proton Mail secure email.
------- Original Message -------
On Thursday, November 2nd, 2023 at 5:12 AM, THOMAS JOB JOSE via grass-user grass-user@lists.osgeo.org wrote:
output=blend
Extracting areas…
Writing areas…
Building areas…
Attaching islands…
r.to.vect complete.
Extracting areas…
Writing areas…
Building areas…
Attaching islands…
r.to.vect complete.
Breaking lines…
Merging lines…
Attaching islands…
Building areas…
Attaching islands…
Writing centroids…
Building areas…
Attaching islands…
v.overlay complete.
Buffering areas…
Cleaning buffers…
Reading features…
Breaking polygons…
Building areas…
Removing dangles…
Removing bridges…
Attaching islands…
Attaching islands…
Building areas…
Attaching islands…
Reading areas…
Writing raster map…
Extracting points…
r.to.vect complete.
Raster MASK removed
Writing attributes…
Region:
main()
run_command
kwargs)
handle_errors
with error
(error) output.
Job Thomas.
