[GRASS-user] GRASS GIS through PyWPS bridge
I want to make a simple web page that uses web processing capabilities of GRASS as a back end and displays image on the webpage.I am using CGI interface of python and PyWPS bridge connecting them .
right now my web page(http://134.129.125.124/) displays a normal JPG image by from .
I want to write a simple python script which uses Grass GIS to convert a TIFF image to png or other formats.This script should run as a back end.
I have pasted my script (http://pastie.org/8529097).But its not working right now.
Can you please give me suggestions ?
Thank You
Nitendra
Hi Nitendra,
First of all this question is related to WPS and CGI than with GRASS.
Did you tried setting up a WPS service and use OpenLayers to read data.
On Wed, Dec 4, 2013 at 9:19 PM, Nitendra Gautam <nitendra.gautam@my.ndsu.edu> wrote:
What you mean not working? You should provide some information like error_log content to get some help. But honestly I am dont know much of PyWPS. I haven’t used it for a long time. you should ask on pywps list to get a better response.
Thank You
Nitendra
grass-user mailing list
grass-user@lists.osgeo.org
Rashad
Hi Nitendra,
your code says
"r.out.png","input=the/tiff/file","out=/the/png/file"
But r.out.png [1] is not converter between image formats (this is what ImageMagic does [2]). If the images are georeferenced then GDAL [3] is the right option for file format conversion. r.out.png exports GRASS raster map, so input should be GRASS raster map not a tiff file.
If you want to use GRASS for this conversion (e.g. this conversion is only example process and in fact you want to do some serious processing in GRASS), you need to import the tiff file first or link it as external map. For import to GRASS use r.in.gdal [4]. For linking the tiff file as external map use r.external [5].
Note that if the tiff has colors it will be splitted into three maps and if you want to show it as one RGB map, you need to use r.composite [6].
Than you can do what ever processing you want and then export the result as PNG using r.out.png.
Hope that helps,
Vaclav
[1] http://grass.osgeo.org/grass70/manuals/r.out.png.html
[2] http://www.imagemagick.org
[3] http://www.gdal.org/
[4] http://grass.osgeo.org/grass70/manuals/r.in.gdal.html
[5] http://grass.osgeo.org/grass70/manuals/r.external.html
[6] http://grass.osgeo.org/grass70/manuals/r.composite.html
On Wed, Dec 4, 2013 at 3:19 PM, Nitendra Gautam <nitendra.gautam@my.ndsu.edu> wrote:
Thank You
Nitendra
Thank You Vaclav Peters for your reply.
Well i am trying to use GRASS GISas a back end server for web processing service.
I did modified my code according to your suggestions but did some mistake on the say
i have pasted my code here(http://pastie.org/8533927).
I think i did some mistake on passing the argument in the function .you can check on link 2 on http://134.129.125.124/.
I am getting the following error message in my error log.
Premature end of script headers: newcode2.py, referer: http://134.129.125.124/
Any suggestions on where i did wrong?
Thank You
Nitendra Gautam
Sent: Friday, December 06, 2013 9:15 AM
To: Nitendra Gautam
Cc: grass-user@lists.osgeo.org
Subject: Re: [GRASS-user] GRASS GIS through PyWPS bridge
Hi Nitendra,
your code says
Hope that helps,
Vaclav
Thank You
Nitendra
On Fri, Dec 6, 2013 at 1:59 PM, Nitendra Gautam <nitendra.gautam@my.ndsu.edu
service.
on the say
The error message is from pyWPS not GRASS, so you need to check with them
how to get something which can you tell more about what happened.
However, I think that you are calling GRASS command in the wrong way:
self.cmd(["r.in.gdal -o", "inp...
I'm not sure about the interface there (in pyWPS) but I guess that it
should be:
self.cmd(["r.in.gdal", "-o", "inp...
Each parameter (grass option or flag in this case) should be a separate
item in the list (self.cmd).
Vaclav
Thank You
Nitendra Gautam
*Sent:* Friday, December 06, 2013 9:15 AM
*To:* Nitendra Gautam
*Cc:* grass-user@lists.osgeo.org
*Subject:* Re: [GRASS-user] GRASS GIS through PyWPS bridge
Hi Nitendra,
your code says
Hope that helps,
Vaclav
image by from <JPG image button>.
right now.
Thank You
Nitendra
