[GRASS-user] GRASS-module to import OSM-data
Hello list,
I wanted to import data from the OpenStreetMap-project to GRASS. I found
a bash-script written by Hamish some (long) time ago and tried it that
way. His script has 3 disadvantages for me:
- It somehow had X and Y swapped (maybe worked correctly for earlier
version of GRASS?)
- It didn't work with OSM-files written by JOSM (Files written by
server/API were OK)
- It's slow (Spawns lot of procs, used tempfiles very often)
So I quite rewrote the script in TCL (using similar techniques but
improved :wink: fixing some stuff.
When I had the thing done, I tried to rewrite it, so it now became a
module for GRASS (though written in TCL).
The script reads the file line-by-line and stores the important stuff in
arrays and then imports the data as vector map using 1 polyline for each
way. Since TCL uses quite a bit of memory for arrays (it's not C after
all), you might not want to import the whole planet.osm.
Since this is my first module for GRASS and things can always be
improved, feedback is very welcome and wanted.
You can find the script here:
http://kripton.kripserver.net/software/v.in.osm
Written for GRASS 6.2.1, not tested for other versions.
Sincerely,
    Jannis
found a bash-script written by Hamish some (long) time ago and tried
it that way. His script has 3 disadvantages for me:
version of GRASS?)
server/API were OK)
in arrays and then imports the data as vector map using 1 polyline for
each way. Since TCL uses quite a bit of memory for arrays (it's not C
after all), you might not want to import the whole planet.osm.
Excellent stuff Jannis. I look forward to trying it out.
Yes, mine was a quick hack just to get it working. I was mostly
interested in building a connected network from all the OSM segments to
try out GRASS's v.net.* and d.path routing modules with real data.
Hopefully OSM has standardized some on road types (dirt, residential,
highway, etc.) since then. I remember correcting for that taking most of
the time. I'll update my google page to list your script once I get my
Debian upgrade finished :wink: Until then perhaps you could add it to the
GRASS Wiki add-ons page?
Hamish
> version of GRASS?)
> server/API were OK)
I would recommend adding it to the SVN repository, but the script
requires tcsh. :frowning:
I'd like to use OSM, but I've found it horribly lacking in both
consistency and metadata.
73, de Brad KB8UYR/6 <rez touchofmadness com>
version of GRASS?)
server/API were OK)
Hello again :wink:
First, to respond to your notes:
Thanks for the feedback, I'll add the module to the mentioned Wiki-page
soon.
Yeah, it needs the tclsh but I don't think it'll be a problem since the
"GRASS Manager" needs that, too. It even requires Tk to run, which my
module doesn't. IMO, Tcl/Tk is found on nearly every Linux-Desktop and
if it's not installed it shouldn't be a big problem to install it.
Sure, OSM doesn't yet cover the world but you're very welcome to
contribute. Metadata-proposes can be done via the wiki, all proposals
are voted upon.
Now to some good news:
I greatly improved the functionality of the script:
- You can now import only nodes or segs if wanted
- You can just import all "roads" (ways with "highway"-tag)
- You can let the script try to import "closed ways" as areas. There's a
little problem here:
    The script just checks, wether the first node of the first segment
(first means segment #1 of the way) and the last node of the last
segment (means segment with the highest number in that way) match. This
must be the case with closed ways but can occur with unordered ways, too
(Way: 3,4,5,1,2 for example). That's why "highway" and "junction"-tagged
ways are ignored at the area-check.
The new script can be downloaded here:
http://kripton.kripserver.net/software/v.in.osm/v.in.osm-2007-07-14-00
the old one has moved to:
http://kripton.kripserver.net/software/v.in.osm/v.in.osm-2007-07-12-00
The old one still contains a bug: it WILL ignore the "output"-parameter
and will always write to "planet_seg".
Finally, I made a screenshot (sorry for the quality, didn't figure out
how to do better, yet):
http://kripton.kripserver.net/software/v.in.osm/screen.jpg
You can see the region I live in there with "visual_bright"-raster-map
as background, the "normal" OSM-data (black), only the roads with
directions (green) and the imported areas (blue). Just ignore the
orange, red and brown overlays.
Enjoy,
    Jannis
[v.in.osm] (openstreetmap.org)
a little problem here:
This must be the case with closed ways but can occur with unordered
ways, too (Way: 3,4,5,1,2 for example). That's why "highway" and
"junction"-tagged ways are ignored at the area-check.
what is a "closed way"? a series of segments forming a route?
road-as-polygon?
Hamish
road-as-polygon?
Hamish
No, not quite. A "series of segments forming a route" is a "way". You
speak about a "closed way" when the segments form a circle in the way
it's described in the OSM-wiki:
"Areas are the polygon of at least 3 segments in a row. The end of the
last segment has to connect to the start of the first."
The OSM-data-scheme doesn't really know "areas", so closed ways are used
to describe areas. There is a discussion wether the key "area" should be
defined to really make sure it's an area:
http://wiki.openstreetmap.org/index.php/Key:area
Jannis
road-as-polygon?
Hamish
Just found another very good link to explain stuff:
http://wiki.openstreetmap.org/index.php/Data_Primitives
Jannis
