[GRASS-user] GRASS project movement
Dear list,
I have a question in terms of GRASS project movement. I would like to archive GRASS projects so that I can still use it but hence it does not take needed space.
So if I package the complete GRASS GIS data directory does it also take the total information including projection, coordinate system… or do I have to start with a new project? (I did not use GRASS for a long time, so…)
I look forward to hear from you.
Regards
Chris
Share your memories online with anyone you want anyone you want.
On Fri, Sep 11, 2009 at 9:11 AM, christian Brandt
<chrisbrandt74@hotmail.com> wrote:
Dear list,
needed space.
total information including projection, coordinate system... or do I have to
start with a new project? (I did not use GRASS for a long time, so...)
You may want to package per location. Locations are independent from
each other (so just put each location directory in a different package).
Perhaps useful to raise the particular status of db data : if you use
dbf driver, the directory will be saved, but if you have an external db
connection, beware of data loss...
> Dear list,
> needed space.
grass-user mailing list
grass-user@lists.osgeo.org
