Pedro, I kindly ask you to keep the discussion on the list - it's very
interesting (to me at least) and of wider interest (I guess) as a small
challenge for grass. I am sure others can help here.
Also, accept my apologies for re-structuring the mail to make it easy to
follow for other readers.
Pedro wrote:
> > I need to implement a Quadratic Mahaloanobis Distance by using GRASS.
> > This is based on medium vector and covariance matrix.
> > 1- As anyone implemented anything similar?
> > 2- If not, Is there any GRASS script that accesses medium vector and
> > Covariance matrix in its processing?
Nikos:
> Not sure at all but my guess is that it's a (simple) job for grass if you
> know the formula. I am not familiar with the term "medium" vector. But
> there is "r.covar" to get the covariance (or correlation) matrix based on
> raster maps.
Pedro:
Medium vector is a vector/array in which each element is the average of
that class in each image
[average in image1; average in image2, ...]
The problem of implemeting this in a script is that it required matrix
calculation. I mean, for each pixel in a class, I will have to multiplicate
byt the covariance matriz and this vector.
I don't have a quick answer on how to do it within grass using r.mapcalc. But
I am convinced that using grass + R is a solution. Also, is the following
matlab (open source?) code of any use?
<http://www.hackchina.com/en/r/129852/mahalanobis.m__html>
I've read on the net efforts trying to link R and matlab. If the latter is
practically doable, then you can even avoid writing the code (again). So, I
imagine something like:
1. import data in grass and prepare/process etc.
2. load data of interest in R
3. calculate the (qudratic) mahalanobis distances of interest (within R with
R code/ with matlab code ?)
4. export results (or even maps) in grass back again
Cheers, Nikos
