[GRASS-user] Grass to R and back again (randomForest classification)
Hi list,
I'm trying to do a randomForest classification in a MODIS NDVI time
series. So far I've been able to generate the randomForest and get the
Grass NDVI images inside grass as a SpatialGridDataFrame. Then,
following some notes from Markus Neteler [1], I converted the
SpatialGridDataFrame to a DataFrame and sucessfully applied the
randomForest classifier. The problem is that now I'm struglling to
transform the DataFrame back to a grass image. What is giving me a
headach is that the images contains lots of null values (I need to
have a MASK in place) so, each NDVI image has 1023701 cells but the
DataFrame has only 264647 values since the conversion from SpatialGrid
to DataFrame skips the nulls.
So, the question is, how to convert my DataFrame back to a Grass image?
Daniel
[1] http://mpa.fbk.eu/markus/shortcourse/notes7.html
PS - For completion sake...
Using Grass 6.4.0RC6 in Ubuntu 9.10
R 2.11
commands used in R:
# open images
ndvi <- readRAST6(<list of 23 ndvi images>)
# convert to dataframe
ndvi.df <- as.data.frame(ndvi)
class <- predict(RFmodel, ndvi.df)
# class contains 264647 classified pixels - how to get them back to an image?
Daniel Victoria:
Daniel,
so far I used the following steps:
# import raster data in R using "readRAST6" of course
x.raw <- readRAST6 (SomeRasterMap) # or readRAST6 (SomeRasterMap , NODATA =
-999999 )
# use complete cases to deal with NA's
x.nonas <- complete.cases ( x@data )
# get values
x <- x.raw@data[x.nonas,]
# add new columns to "x.raw" that will be fed with... "newvalues"
x.raw@data$column1 <- NA
x.raw@data$column2 <- NA
[etc.]
# do something with your data or create new data.frame(s)
# fill in the new (empty) columns of xraw
x.raw@data$column1[x.nonas] <- new.data.frame$newslot[,"newcolumn"]
[etc.]
# write back to grass
writeRAST6(x.raw, zcol= NumberOfNewColumn, vname="SomeNameForTheRaster",
overwrite=TRUE)
Something like that... Hope it helps,
Nikos
R 2.11
commands used in R:
# open images
image?
Thanks Nikos, it worked like a charm!
I'd also like to thaks Ned Horning for some greatlly aprecciated
off-list R help!
Daniel
On Fri, Jun 11, 2010 at 9:39 AM, Nikos Alexandris
<nikos.alexandris@felis.uni-freiburg.de> wrote:
Daniel Victoria:
Daniel,
-999999 )
# get values
[etc.]
[etc.]
overwrite=TRUE)
Nikos
R 2.11
commands used in R:
# open images
image?
