Hi Sergio,
Take a look at the link below. I had the same problem last week (among others ) while trying to install grass70 on ubuntu 14.04. The script kindly made available by hamish made the trick for me. Good luck
https://www.mail-archive.com/grass-user@lists.osgeo.org/msg28495.html
Best regards
Rengifo
“grass-user-request@lists.osgeo.org” grass-user-request@lists.osgeo.org schrieb am 21:00 Mittwoch, 27.August 2014:
Send grass-user mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body ‘help’ to
You can reach the person managing the list at
grass-user-owner@lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than “Re: Contents of grass-user digest…”
Today’s Topics:
- Job Vacancy: Geospatial Software Engineer in Luxembourg
(Christian Braun) - problem to install grass70 on ubuntu 12.04 (Sergio Vignali)
- Re: problem to install grass70 on ubuntu 12.04 (Markus Neteler)
Message: 1
Date: Wed, 27 Aug 2014 09:46:36 +0200
To: GRASS user list <grass-user@lists.osgeo.org>,
freegis-list@intevation.de
Subject: [GRASS-user] Job Vacancy: Geospatial Software Engineer in
Luxembourg
Message-ID: <8EF1FEA6-ABCC-4716-982E-8AE26FDCF647@tudor.lu>
Content-Type: text/plain; charset=“us-ascii”
Dear all,
our Institute is looking for a candidate as a Geospatial Software Engineer.
Work will focus on the development of a geospatial web based framework, implementing OGC standards for sensor, data, catalogue and modelling services, enabling service based scenario simulation and decision support tools.
Further information and contact details can found here:
http://tudor.lu/en/job/geospatial-software-engineer-mf
Please apologize cross-posting.
kind regards,
Christian Braun
R+D Engineer
Environmental Modelling, Geocomputation
Tel: +352- 425991-6608
Mobil: +49-179-6845896
Mail: christian.braun@tudor.lu
Resource Centre for Environmental Technologies,
Public Research Centre Henri Tudor,
6A, avenue des Hauts-Fourneaux,
L-4362 Esch-sur-Alzette, Luxembourg
An HTML attachment was scrubbed…
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140827/3408f315/attachment-0001.html>
Message: 2
Date: Wed, 27 Aug 2014 10:34:03 +0200
Subject: [GRASS-user] problem to install grass70 on ubuntu 12.04
Message-ID:
<CALLUJBbZJ-=h0N0oj6wM9moHRZ6skNnd12pt4v6s-JNXXYKMsA@mail.gmail.com>
Content-Type: text/plain; charset=“utf-8”
I’ve just tried to install grass70 on ubuntu 12.04 by these command
sudo add-apt-repository ppa:grass/grass-stable
sudo apt-get update
sudo apt-get install grass70 grass70-gui
the error says that there are damaged or blocked packages
All the best
Sergio Vignali
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140827/e8ead687/attachment-0001.html>
Message: 3
Date: Wed, 27 Aug 2014 18:52:44 +0200
To: Sergio Vignali <vignalisergio30@gmail.com>
Cc: GRASS user list <grass-user@lists.osgeo.org>
Subject: Re: [GRASS-user] problem to install grass70 on ubuntu 12.04
Message-ID:
<CALFmHhuMMzu8ZWPWaMROtrAmo+5Pct-Yk12j_7uTT=K1M9WY6A@mail.gmail.com>
Content-Type: text/plain; charset=UTF-8
Hi Sergio,
On Wed, Aug 27, 2014 at 10:34 AM, Sergio Vignali
<vignalisergio30@gmail.com> wrote:
I’ve just tried to install grass70 on ubuntu 12.04 by these commandsudo add-apt-repository ppa:grass/grass-stable
sudo apt-get update
sudo apt-get install grass70 grass70-guithe error says that there are damaged or blocked packages
To better understand, I have created a virtual machine with Ubuntu
12.04 and tried myself. In fact:
pgis@pgis-ubuntu64-vm:~$ sudo apt-get install grass70 grass70-gui
Reading package lists… Done
Building dependency tree
Reading state information… Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
grass70 : Depends: grass70-core but it is not going to be installed
grass70-gui : Depends: grass70-core but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
So I tried harder:
pgis@pgis-ubuntu64-vm:~$ sudo apt-get install grass70 grass70-core grass70-gui
grass70-core : Depends: libgdal1h (>= 1.8.0) but it is not installable
Depends: libgeos-c1 (>= 3.4.2) but it is not going to
be installed
Depends: libproj0 (>= 4.8.0-1) but it is not going to
be installed
Recommends: gdal-bin but it is not going to be installed
Recommends: proj-bin but it is not going to be installed
Breaks: grass70 (< 7.0.0+0ubuntu3~)
Not sure what the next step is (I am more experienced with RPM based systems).
Likely it can be solved
Message: 4
Date: Wed, 27 Aug 2014 20:08:29 +0200
Message-ID:
<CALFmHhu9afZMX_8fO+G4eOZBjzEAyWijpOcrSt+AjFEQPycJCg@mail.gmail.com>
On Wed, Aug 27, 2014 at 6:52 PM, Markus Neteler <neteler@osgeo.org> wrote:
Hi Sergio,
<vignalisergio30@gmail.com> wrote:Hi,
sudo apt-get update
12.04 and tried myself. In fact:pgis@pgis-ubuntu64-vm:~$ sudo apt-get install grass70 grass70-gui
The following information may help to resolve the situation:The following packages have unmet dependencies:
pgis@pgis-ubuntu64-vm:~$So I tried harder:
be installed
be installed
E: Unable to correct problems, you have held broken packages.Not sure what the next step is (I am more experienced with RPM based systems).
Just to complete the tests, also this fails at time:
Depends: grass70-gui but it is not going to be installed
End of grass-user Digest, Vol 100, Issue 24
