[GRASS-user] grass-user Digest, Vol 205, Issue 33
Dear Markus, Tom and Valcus,
Thank you very much for your invaluable reply.
I tried to ask ChatGPT as Markus suggested.
However, I can not figure out which web api are available for active cyclone/hurrican/typhoon so that I can test them with the aid of AI.
Any hints?
Below is the code generated by ChatGPT.
import requests import json import grass.script as gscript # Function to download data from a URL def download_data(url, output_file): response = requests.get(url) with open(output_file, ‘wb’) as file: file.write(response.content) # Function to import meteorological data into GRASS GIS def import_data(file_path, map_name): gscript.run_command(‘r.in.gdal’, input=file_path, output=map_name) # Function to track cyclones using GRASS GIS modules def track_cyclones(data_map): # Set computational region to match the imported data gscript.run_command(‘g.region’, raster=data_map) # Perform cyclone tracking analysis using GRASS modules # Replace the following commands with the appropriate GRASS GIS modules and parameters for cyclone tracking # Example: # gscript.run_command(‘r.mapcalc’, expression=‘cyclone_track = …’) # Print a message indicating the completion of the tracking process gscript.message(‘Cyclone tracking completed.’) # Define URLs for downloading data from NOAA, NHC, and JTWC noaa_url = https://example.com/noaa_data.nc’ nhc_url = ‘https://example.com/nhc_data.nc’ jtwc_url = ‘https://example.com/jtwc_data.nc # Define output file paths noaa_file = ‘/path/to/noaa_data.nc’ nhc_file = ‘/path/to/nhc_data.nc’ jtwc_file = ‘/path/to/jtwc_data.nc’ # Download meteorological data from NOAA, NHC, and JTWC download_data(noaa_url, noaa_file) download_data(nhc_url, nhc_file) download_data(jtwc_url, jtwc_file) # Import meteorological data into GRASS GIS import_data(noaa_file, ‘noaa_data’) import_data(nhc_file, ‘nhc_data’) import_data(jtwc_file, ‘jtwc_data’) # Track cyclones using the imported data track_cyclones(‘noaa_data’) # Replace ‘noaa_data’ with the appropriate data map name # Clean up: remove the downloaded data files if desired # Uncomment the following lines if you want to delete the downloaded files # import os # os.remove(noaa_file) # os.remove(nhc_file) # os.remove(jtwc_file)
Best regards,
Kyaw Moe Aung
On Thu, May 25, 2023 at 1:31 AM <grass-user-request@lists.osgeo.org> wrote:
Send grass-user mailing list submissions to
grass-user@lists.osgeo.org
To subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body ‘help’ to
You can reach the person managing the list at
grass-user-owner@lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than “Re: Contents of grass-user digest…”
Today’s Topics:
  1. Re: Active Tropical Cyclone Tracking with GRASS GIS and
    Jupyter Notebook (Thomas Adams)
  2. Re: Active Tropical Cyclone Tracking with GRASS GIS and
    Jupyter Notebook (Markus Neteler)
  3. Re: Active Tropical Cyclone Tracking with GRASS GIS and
  4. Re: Active Tropical Cyclone Tracking with GRASS GIS and
Message: 1
Date: Wed, 24 May 2023 11:56:53 -0400
To: Vaclav Petras <wenzeslaus@gmail.com>
Cc: kyawmoeaung.kyawmoe@gmail.com, grass-user@lists.osgeo.org
Subject: Re: [GRASS-user] Active Tropical Cyclone Tracking with GRASS
GIS and Jupyter Notebook
Message-ID:
<CAGxgkWjGGWje25g0Wu+R1yHvfXSJCohzVsTriUoyQjJr34tFRQ@mail.gmail.com>
Content-Type: text/plain; charset=“utf-8”
Yes ? agreed that a lot of scripting would be needed, but importing readily
available data is very doable.
Tom
On Mon, May 22, 2023 at 2:17?PM Vaclav Petras <wenzeslaus@gmail.com> wrote:
Hi Kyaw,
I think it is fairly safe to say that GRASS GIS supports that, but someone
would need to create that specific workflow or notebook.
Best,
Vaclav
On Tue, 16 May 2023 at 23:59, <kyawmoeaung.kyawmoe@gmail.com> wrote:
I am just wondering whether GRASS GIS supports tracking active and
archive cyclones/hurricanes/typhoons as was found in ArcGIS using living
atlas and ArcGIS online platform.
I noticed that they are using NOAA and other satellite sensors.
Thank you very much.
Kyaw Moe Aung
Consultant
PyJuliaR Consulting Firm
Thomas E Adams, III
207 Chowning Place
Blacksburg, VA 24060
tea3rd@gmail.com (personal)
tea@terrapredictions.org (work)
1 (513) 739-9512 (cell)
An HTML attachment was scrubbed…
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20230524/d321cc9d/attachment-0001.htm>
Message: 2
Date: Wed, 24 May 2023 18:21:40 +0200
To: Thomas Adams <tea3rd@gmail.com>
Cc: Vaclav Petras <wenzeslaus@gmail.com>,
Message-ID:
<CALFmHhvmjkz1Vmbs1BdQMVpe5d=qk0xzgXendWkrYuhCMxWuug@mail.gmail.com>
Content-Type: text/plain; charset=“UTF-8”
On Wed, May 24, 2023 at 5:57?PM Thomas Adams <tea3rd@gmail.com> wrote:
Yes ? agreed that a lot of scripting would be needed, but importing readily available data is very doable.
Being in modern times, you can generate the majority of the script
(Jupyter notebook) even with an AI.
Best,
Message: 3
Date: Wed, 24 May 2023 12:23:28 -0400
To: Markus Neteler <neteler@osgeo.org>
Cc: Vaclav Petras <wenzeslaus@gmail.com>, grass-user@lists.osgeo.org,
Message-ID:
<CAGxgkWhRo2=8O4XpRmZxZFRL3qeWApvUo7uXZO1n5+Z5MG8Oig@mail.gmail.com>
I guess I?m pathetically old school ???
Best,
Sent from Gmail Mobile
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20230524/a8b13e0d/attachment-0001.htm>
Message: 4
Date: Wed, 24 May 2023 18:28:25 +0200
Message-ID:
<CALFmHhud77OodEq0O1SfOMaPzsQv=XZJm4WgAB6bo+ux26ob1Q@mail.gmail.com>
It is “just” for reducing the workload - still we need to be able to
check what the AI suggests :slight_smile:
Just wanted to point out that some new helper tools are available.
Subject: Digest Footer
End of grass-user Digest, Vol 205, Issue 33
If NOAA data is CF-convention-compliant data in NetCDF format, you may check out: https://grass.osgeo.org/grass82/manuals/addons//t.rast.import.netcdf.html
And https://grass.osgeo.org/grass82/manuals/addons/m.crawl.thredds.html
if the data is distributed via threads server…
Stefan
Any hints?
Best regards,
Kyaw Moe Aung
Today’s Topics:
Message: 1
Message-ID:
Tom
Hi Kyaw,
Best,
Vaclav
Kyaw Moe Aung
Consultant
Thomas E Adams, III
207 Chowning Place
Message: 2
Message-ID:
Best,
Message: 3
Message-ID:
Best,
Message: 4
Message-ID:
_______________________________________________ grass-user mailing list grass-user@lists.osgeo.org https://lists.osgeo.org/mailman/listinfo/grass-user
