[GRASS-user] Grass-Windows - Error using tcltk's messages
Greetings
I have compiled GRASS6.4 with Osgeo4w and it worked just fine. Then I decided to create an installer and it worked just fine but… tcltks translation is not working. I only need the v.digit . And it’s not working for any language. Any tips on what might be happening?
Thanks
Luisa Pena
On Tue, Jun 7, 2011 at 5:35 PM, Luisa Peña <luisapena1979@gmail.com> wrote:
Greetings
decided to create an installer and it worked just fine but... tcltks
translation is not working. I only need the v.digit . And it's not working
The messages were not tagged for translation in GRASS 6.4.
I have backported that now, still have to update the .po files
(asap).
Hello Markus. Thank you for your reply
In my case I’m using an older version of grass 6.4.1 over which I built a lot of functions and change the GUi (a lot) in order to meet my users (colleagues and teachers) needs. What can I do to fix this?
Thanks
2011/6/9 Markus Neteler <neteler@osgeo.org>
Greetings
(asap).
Greetings
(asap).
Also done in SVN!
Hello,
as goes for windows users - they are out of luck. You can try to
simply copy self compiled/nightly v.digit over old version, still I
have no idea if it could work. On Linux it's just a matter of
recompiling only v.digit module.
Maris.
2011/6/9, Luisa Peña <luisapena1979@gmail.com>:
In my case I'm using an older version of grass 6.4.1 over which I built a
Thanks
wrote:
> Greetings
working
(asap).
Ok…
But the weirdeist thing is that it works on compiled version but when I try to create an installer, it does not work at all (for all interfaces). Any comments on this?
Thanks
2011/6/15 Maris Nartiss <maris.gis@gmail.com>
Hello,
have no idea if it could work. On Linux it’s just a matter of
Maris.
Thanks
wrote:
Greetings
working
(asap).
