[GRASS-user] GRASS7 d.mon
Hi List,
In GRASS 7 (SVN from 11/10/2013) I have a problem when I try to display a raster using d.mon, i.e.:
bash-4.2$ d.mon start=wx0
bash-4.2$ d.rast global_total
ERROR: Cairo_begin_raster: Failed to create surface
Vectors display fine using d.vect and I can view the above mentioned raster when I load it thro’ the wxGUI. I’ve compiled GRASS7 with CAIRO support.
Couldn’t find help online.
Thanks in advance.
Best Regards,
Daniel
2013/10/14 Daniel McInerney <daniel.o.mcinerney@gmail.com>:
this error comes from [1]. What version of cairo do you have?
Martin
[1] http://trac.osgeo.org/grass/browser/grass/trunk/lib/cairodriver/Raster.c#L67
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
Hi Martin,
cairo.x86_64 1.12.14-2.fc18 @updates
It configured ok tho.
Best Regards,
Daniel
On Mon, Oct 14, 2013 at 11:49 AM, Martin Landa <landa.martin@gmail.com> wrote:
Martin
@updates
hm, I expect that displaying rasters from wxGUI also doesn't work, right? Martin
Yes, you’re right, it doesn’t display in wxGUI either - I thought that it had been working over the w/e.
Daniel
On Mon, Oct 14, 2013 at 11:56 AM, Martin Landa <landa.martin@gmail.com> wrote:
@updates
hm, I expect that displaying rasters from wxGUI also doesn’t work, right? Martin
Yes, you're right, it doesn't display in wxGUI either - I thought that it
please try r57994. It should at least print more details in error message.
Martin
Many thanks Martin, that revision has solved the problem.
Daniel
On Mon, Oct 14, 2013 at 3:21 PM, Martin Landa <landa.martin@gmail.com> wrote:
Martin
Hi Daniel,
in this revision I just changed the error message to report more
detailed info about failure. So it cannot be the reason why it's
working now for you. Martin
ok. the only difference this time, is that i passed --with-cairo to ./configure. Having said that the previous install had cairo support. I also updated the region settings before running d.rast.
Daniel
On Mon, Oct 14, 2013 at 5:38 PM, Martin Landa <landa.martin@gmail.com> wrote:
Hi Daniel,
detailed info about failure. So it cannot be the reason why it’s
