[GRASS-user] GRASS7: problems with WMS
Hi All,
I am trying to load a WMS using GRASS7, which I compiled from svn/release branch.
Connecting to the WMServer, selecting and adding a layer works fine, but I do not get any image into the map display.
The GUI's Map Console reports:
Unable to determine region, m.proj failed
The console, from which I started the GUI says:
ERROR 4: `/path/to/mapset/.tmp/hostname/3199.12' does not exist in the file system, and is not recognised as a supported dataset name.
After noting the error related to region/m.proj, I tried both: to load a WMS in EPSG:3035 into my LAEA location and to load another WMS in EPSG:4326 into my WGS84 location, whithout any luck.
Any hints?
Thanks in advance, Hermann
Just to add that I continue trying to load the WMS, without success, though. My current error message is:
ERROR 4: `/home/peifer/grassdata/laea/test/.tmp/whitefish/17189.4' does not exist in the file system, and is not recognised as a supported dataset name.
When looking into .tmp/whitefish, I see a series of 17189.* files, but obviously not 17189.4:
[GRASS:test]> ls -l .tmp/whitefish/
total 1184
-rw-r--r-- 1 peifer mtr 1144239 Sep 18 19:18 17189.0.ppm
-rw-r--r-- 1 peifer mtr 9125 Sep 18 19:10 17189.10
-rw-r--r-- 1 peifer mtr 8903 Sep 18 19:10 17189.11
-rw-r--r-- 1 peifer mtr 574 Sep 18 19:10 17189.5
-rw-r--r-- 1 peifer mtr 9125 Sep 18 19:10 17189.6
-rw-r--r-- 1 peifer mtr 8903 Sep 18 19:10 17189.7
-rw-r--r-- 1 peifer mtr 574 Sep 18 19:10 17189.8
-rw-r--r-- 1 peifer mtr 574 Sep 18 19:10 17189.9
On 2014-09-18 8:41, Hermann Peifer wrote:
Hi All,
svn/release branch.
Any hints?
Hi Hermann,
would be possible to send me the WMS service URL you are trying to connect?
Best
Stepan
---------- Původní zpráva ----------
Od: Hermann Peifer peifer@gmx.eu
Komu: GRASS user list grass-user@lists.osgeo.org
Datum: 18. 9. 2014 19:24:44
Předmět: Re: [GRASS-user] GRASS7: problems with WMS
ERROR 4: `/home/peifer/grassdata/laea/test/.tmp/whitefish/17189.4’ does
dataset name.
total 1184
-rw-r–r-- 1 peifer mtr 1144239 Sep 18 19:18 17189.0.ppm
-rw-r–r-- 1 peifer mtr 9125 Sep 18 19:10 17189.10
-rw-r–r-- 1 peifer mtr 8903 Sep 18 19:10 17189.11
-rw-r–r-- 1 peifer mtr 574 Sep 18 19:10 17189.5
-rw-r–r-- 1 peifer mtr 9125 Sep 18 19:10 17189.6
-rw-r–r-- 1 peifer mtr 8903 Sep 18 19:10 17189.7
-rw-r–r-- 1 peifer mtr 574 Sep 18 19:10 17189.8
-rw-r–r-- 1 peifer mtr 574 Sep 18 19:10 17189.9
Hi All,
svn/release branch.
The GUI’s Map Console reports:
ERROR 4: `/path/to/mapset/.tmp/hostname/3199.12’ does not exist in the
Any hints?
grass-user mailing list
As far as I tried out: the error occurs for any WMS in any projection, including all the built-in servers. It looks like no other GRASS7 user ever had the same issue, which is surprising. From the error message, I assume that soemthing is going systematically wrong with the numbering of the files in the .tmp directory.
I am currently trying with layer: "WMS Global Mosaic, pan sharpened" from the built-in server list: http://onearth.jpl.nasa.gov/wms.cgi
The result is:
ERROR 4: `/home/peifer/grassdata/wgs84/PERMANENT/.tmp/whitefish/32754.4' does not exist in the file system, and is not recognised as a supported dataset name.
File 32754.4 does indeed not exist. See below.
Hermann
[GRASS:PERMANENT]> file .tmp/whitefish/*
.tmp/whitefish/32754.0.ppm: Netpbm PPM "rawbits" image data
.tmp/whitefish/32754.10: XML document text
.tmp/whitefish/32754.11: XML document text
.tmp/whitefish/32754.5: XML document text
.tmp/whitefish/32754.6: XML document text
.tmp/whitefish/32754.7: XML document text
.tmp/whitefish/32754.8: HTML document text
.tmp/whitefish/32754.9: XML document text
On 2014-09-18 22:31, Štěpán Turek wrote:
Hi Hermann,
Best
Stepan
Od: Hermann Peifer <peifer@gmx.eu>
Komu: GRASS user list <grass-user@lists.osgeo.org>
    dataset name.
    total 1184
     > Hi All,
     > I am trying to load a WMS using GRASS7, which I compiled from
     > svn/release branch.
     > Connecting to the WMServer, selecting and adding a layer works
    fine, but
     > I do not get any image into the map display.
     > The GUI's Map Console reports:
     > Unable to determine region, m.proj failed
     > The console, from which I started the GUI says:
     > ERROR 4: `/path/to/mapset/.tmp/hostname/3199.12' does not exist
    in the
     > file system, and is not recognised as a supported dataset name.
     > After noting the error related to region/m.proj, I tried both: to
    load a
     > WMS in EPSG:3035 into my LAEA location and to load another WMS in
     > EPSG:4326 into my WGS84 location, whithout any luck.
     > Any hints?
     > Thanks in advance, Hermann
Maybe this helps to locate the problem. If not: I simply have to give up
loading a WMS with GRASS7. Hermann
[GRASS6.4.5svn]> r.in.wms map=http://wms.cuzk.cz/wms.asp out=wms layers=kn
srs=EPSG:3035 format=png
Calculating tiles
Requesting 30 tiles.
Downloading tiles
[GRASS7.0.0svn]> r.in.wms url=http://wms.cuzk.cz/wms.asp out=wms layers=kn
srs=3035 format=png
ERROR: Sorry, <input> is not a valid parameter
ERROR: Unable to determine region, m.proj failed
View this message in context: http://osgeo-org.1560.x6.nabble.com/GRASS7-problems-with-WMS-tp5162533p5162883.html
The result is:
dataset name.
I get the same, however in the gui console I also get:
WMS server error: <?xml version='1.0' encoding="UTF-8"
standalone="no" ?>
<!DOCTYPE ServiceExceptionReport SYSTEM
"http://wms.jpl.nasa.gov/exception_1_1_1.dtd ">
<ServiceExceptionReport version="1.1.1">
<ServiceException>
This server no longer provides full WMS services!
</ServiceException>
</ServiceExceptionReport>
so this service doesn't work any more.
Anna
Hermann
Hi Hermann,
connect?
Best
Stepan
does
    dataset name.
    total 1184
     > Hi All,
    fine, but
    in the
    load a
     > Any hints?
Calculating tiles
Downloading tiles
srs=3035 format=png
I have no idea, the <input> probably refers to m.proj but m.proj has input
parameter. Could you try to run only m.proj (take some example from
manual), if it works?
Anna
input parameter. Could you try to run only m.proj (take some example
from manual), if it works?
Either I am doing something terribly stupid, or m.proj is *really* broken in the release branch. I wonder what m.proj or cs2cs is expected to do with colors: [color=style] and [color=name]. Furthermore: no coordinate input seems to be needed, see [1]. This parameter list looks like a joke, to say it in a friendly way.
I "fixed" all of my earlier reported issues related to m.proj and loading a WMS by moving from the GRASS7 release branch to svn/trunk. In trunk, m.proj has a reasonable parameter list [2] and loading the WMS works as expected.
Hermann
[1] Welcome to GRASS 7.0.0svn (r61824)
[GRASS:test]> m.proj --h
Description:
  Converts coordinates from one projection to another (cs2cs frontend).
Keywords:
  miscellaneous, projection
Usage:
  m.proj [-iodec] [color=style] [output=name] [separator=character]
    [color=name] [proj_in=string] [proj_out=string] [--overwrite] [--help]
    [--verbose] [--quiet]
[2] Welcome to GRASS 7.1.svn (r62036)
[GRASS:PERMANENT]> m.proj --help
Description:
Keywords:
Usage:
  m.proj [-iodec] [coordinates=east,north] [input=name] [output=name]
    [separator=character] [proj_in=string] [proj_out=string] [--overwrite]
    [--help] [--verbose] [--quiet]
yes, that's pretty funny. Do you have any local changes (svn diff)? I
looked in the recent changes but there is nothing suggesting this error.
expected.
Hermann
Description:
Keywords:
Usage:
Description:
Keywords:
Usage:
No diff at all. And until yesterday, I did not even know that m.proj existed.
Hermann
existed.
This might help the initiated to find some bug:
diff grass/scripts/m.proj/m.proj.py grass70_release/scripts/m.proj/m.proj.py
38c38
< #% description: '-' for standard input
> #% description: '-' to read from standard input
96d95
< from grass.script.utils import separator, parse_key_val
162,163c161,162
< ifs = separator(ifs)
< ofs = separator(ofs)
> ifs = grass.separator(ifs)
> ofs = grass.separator(ofs)
167c166
< kv = parse_key_val(s)
> kv = grass.parse_key_val(s)
existed.
m.proj.py
38c38
96d95
162,163c161,162
167c166
This cannot cause the problem, so let's try something else.
When in GRASS command line do
which m.proj
Then open the file which it will tell and also make a diff of that file
with grass70_release/scripts/m.proj/m.proj.py
Afterwards, you can also try to recompile GRASS (make distclean &&
./configure ... && make).
Calculating tiles
Downloading tiles
Fine.
[GRASS7.0.0svn]> r.in.wms url=http://wms.cuzk.cz/wms.asp out=wms layers=kn srs=3035 format=png
Which version (g.version -g) do you use?
I have made a test:
GRASS 7.0.0svn (latlong):~ > g.region n=90 s=-90 w=-180 e=180
res=0:30:00 -pprojection: 3 (Latitude-Longitude)
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 90N
south: 90S
west: 180W
east: 180E
nsres: 0:30
ewres: 0:30
rows: 360
cols: 720
cells: 259200
GRASS 7.0.0svn (latlong):~ > r.in.wms
url=http://watzmann-geog.urz.uni-heidelberg.de/cached/osm
layers=osm_auto:all output=osm format=png --o
Downloading data from WMS server...
Importing raster map into GRASS...
WARNING: Raster map <osm> already exists and will be overwritten
<osm> created.
WARNING: Raster map <osm.alpha@neteler> is a base map for <MASK@neteler>.
         Remove forced.
GRASS 7.0.0svn (latlong):~ > g.version -g
version=7.0.0svn
date=2014
revision=62008
build_date=2014-09-17
build_platform=x86_64-unknown-linux-gnu
Works ok with the OSM server.
I actually did that, without any further investigations. After make distclean, I also used: svn up, which brought me from r61824 to r62033.
When comparing the output of make to what I got 12 days ago, I see a difference related to grass70_release/dist.x86_64-unknown-linux-gnu/etc/python/grass/script/utils.py. Maybe this has to do with my problems, maybe not.
In any case: all reported issues are gone now and loading a WMS just works as expected. Thanks to all for their time.
Hermann
