Hello all.
I have done this before on different installs, but this time I can’t get it right.
I am trying to add a table to a postgres database, by importing a .shp-file. It fails to import the table and gives this error:
DBMI-PostgreSQL driver error:
Connection failed.
fe_sendauth: no password supplied
I have set the password like this
db.login driver=pg database=marine_box user=xxx password=xxx
and the connection like this:
db.connect driver=pg database=“host=localhost,dbname=marine_box”
Is this not way to do it?
I also tried to copy a table from dbf to pg without success.
are there any other parameters that need to be set?
I installed grass70 using the ppa found here:
https://launchpad.net/~grass/+archive/grass-devel
I have also recently upgraded to ubuntu 13.04
Martin
