[GRASS-user] grass82 with_opencl in Debian 12
Hello everyone
I installed Debian 12.
I found grass-gis 8.2.1
But it's not configured to work in opencl, and 3d rendering is very
slow.
I tried to install it from sources, but I find several errors. Has
anyone tried and knows how to give the right configuration with
with_opencl in Debian?
Thank you
Enrico Gabrielli
Hi Enrico,
On Mon, Jun 26, 2023 at 3:59 PM bonushenricus <bonushenricus76@gmail.com> wrote:
Hello everyone
slow.
It is actually "openGL" to be installed, see
https://github.com/OSGeo/grass/blob/main/REQUIREMENTS.md#optional-packages
HTH,
Markus Neteler, PhD
https://www.mundialis.de - free data with free software
https://grass.osgeo.org
https://courses.neteler.org/blog
Wel there IS an openCL too :slight_smile: In QGIS:
https://www.itopen.it/opencl-acceleration-now-available-in-qgis/
'naming is important' :slight_smile:
Richard Duivenvoorde
On 6/26/23 16:04, Markus Neteler wrote:
Hi Enrico,
Hello everyone
slow.
HTH,
Richard Duivenvoorde <rdmailings@duif.net> schrieb am Mo., 26. Juni 2023, 21:36:
Sure, it exists. But:
In QGIS:
‘naming is important’ :slight_smile:
And this works in GRASS GIS as well?
Hi Enrico,
Hello everyone
But it’s not configured to work in opencl, and 3d rendering is very
slow.
It is actually “openGL” to be installed, see
HTH,
Hi and thanks
Yes QGIS runs the 3D rendering very well
For GRASS-GIS with the most simple
CFLAGS=-O2 ./configure
i have at the end a problem in DEBIAN 12 because the pdal library
doesn't exist in the stable repository
so the configuration done:
Package pdal was not found in the pkg-config search path.
Perhaps you should add the directory containing `pdal.pc'
to the PKG_CONFIG_PATH environment variable
Package 'pdal', required by 'virtual:world', not found
configure: error: *** Unable to locate suitable (>=1.7.1) PDAL
library
The formal installation (from the website of PDAL) with conda doesn't
change anything.
Bye
Il giorno lun, 26/06/2023 alle 21.29 +0200, Richard Duivenvoorde ha
scritto:
> Hi Enrico,
> > Hello everyone
> > very
> > slow.
> HTH,
> Markus
There are two options for PDAL – either disable completely (no import
tools for LAS files then) or provide paths for include and lib
directories. See ./configure --help for correct syntax of all
parameters. I have no idea if one can mix conda and native libs in a
single program.
Good luck,
Māris.
otrd., 2023. g. 27. jūn., plkst. 08:21 — lietotājs bonushenricus
(<bonushenricus76@gmail.com>) rakstīja:
Hi and thanks
> library
change anything.
Bye
scritto:
> Regards,
> > Hi Enrico,
> > > Hello everyone
> > > very
> > > slow.
> > HTH,
> > Markus
grass-user mailing list
grass-user@lists.osgeo.org
Ok
I found the page for the installation of the pdal from the source
https://pdal.io/en/2.4.3/development/compilation/unix.html
and after the compilation of GRASS with CFLAGS=-O2 ./configure was done
without problem!!
I have now GRASS83 with opengl: the rendering is perfect now!
single program.
Good luck,
Māris.
> Hi and thanks
> > library
> doesn't
> change anything.
> Bye
> scritto:
> > Regards,
> > > Hi Enrico,
> > > > Hello everyone
> > > > is
> > > > very
> > > > slow.
> > > HTH,
> > > Markus
