On using "d.what.vect -e map=roads" and after clicking on map, it
display information, but, I am not able to edit category number in that.
Manual says that -e option will open form in edit mode. Where I am
wrong?
Also I am not able to query using following:
echo "select * from roads" | db.select
It throws following error:
DBMI-DBF driver error:
Table 'roads' doesn't exist.
Error in db_open_select_cursor()
that. Manual says that -e option will open form in edit mode. Where I
am wrong?
you can not change maps that are in the PERMANENT mapset.
make a local copy first,
g.copy vect=roads,roads_local
and check if a DB connection exists for the map:
G61 > v.db.connect -p roads
Vector map <roads> is connected by:
layer <1> table <roads> in database </home/hamish/grassdata/spearfish60/PERMANENT/dbf/> through driver <dbf> with key <cat>
You have to check the edit box in the Display manager (DM).
Then you can simple enter the attribute from Key board.
User permissions of Linux also my come in the way. See that you have
permission to write on the file.
You second DB related proble is not clear Pl.
You can goto the dataset and open the *.dbf files in open office too
for any modification. This is acceptable to GRASS.
Ravi Kumar
On using “d.what.vect -e map=roads” and after clicking on map, it
wrong?
echo “select * from roads” | db.select
Table ‘roads’ doesn’t exist.
that.
You can't edit a category number. You can only edit attributes (besides
the key column, usually and by default called "cat"). Category is a
unique vector feature ID - if you could edit it, you would loose
connection between the vactor feature and it's attributes in table.
Read: http://grass.itc.it/grass61/manuals/html61_user/vectorintro.html
Maciek
W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko najlepsze z nich! http://katalog.panoramainternetu.pl/
You can edit categories with v.category can't you?
Although it seems that only systematic changes, such as adding a value
to all categories, or generating a new category index.
Does anyone know if all vector objects MUST have a unique category?
I have a shape file of US counties, and want to link it to a table of
county information which have the FIPS code as a key. However, because
counties are not all singular vector objects some have more than one
category.
I could link the county information directly to the category numbers.
But this would end having lots of duplicate entries where the FIPS
code of entries is the same but with different category numbers.
Ideally I'd like to be able to use the FIPS code as the category
number - but if category number must unique then I have to go with
duplicate entries.
-Joel
"Wish not to seem, but to be, the best."
-- Aeschylus
Yes, but that's a different thing than Hardeep asked, I think.
No.
category.
Do you mean that one county happens to be represented by more than 1
areas (polygons)?
You can have one category for many objects. Then each object will have
all the attributes in a table that are assigned to that category.
What's FIPS?
as the category
duplicate entries.
Vector objects do NOT need to have a unique cat. Look at roads in the
Spearfish demo set. You can use layers to give each object a unique cat for
one layer and group them by cats in another layer.
Michael
Arizona State University
category.
duplicate entries.
-Joel
-- Aeschylus
Hi
This command has provided hours or entertainment for me too. Usually I can get it to work by meticulously following the format in example 1 on the help page. To this end you might try making the W and N into column headers, decimalize the lat/long and 'note the blank before entering vertex coordinates'. Adding a columns= string helps too. (columns='x double, etc). Good luck.
Stuart
On Jul 14, 2006, at 4:07 PM, gary wrote:
I changed the input format but got the same cryptic error message.
Markus Neteler wrote:
On Thu, Jul 13, 2006 at 01:30:43AM -0700, gary wrote:
I find this error message from v.in.ascii a bit cryptic.
error message:
Maximum input row length: 24
Maximum number of columns: 2
Minimum number of columns: 0
GRASS_INFO_ERROR(15897,1): x column number > minimum last column number
GRASS_INFO_ERROR(15897,1): (incorrect field separator?)
The file site. dat is one line as follows
W115 58 2.4|N36 27 20.9
The default separator is "pipe", so I'm sure the delimiter is fine. Any idea what I'm doing wrong here?
I guess that formatting should be
115:58:2.4W|36:27:20.9N
instead of
grassuser mailing list
grassuser@grass.itc.it http://grass.itc.it/mailman/listinfo/grassuser
Just an FYI, there is a method described in the Markus' "Grass 6 in a Nutshell" to use QGIS to generate a vector map (Section 6.8). The command sequence works fine, but GRASS complains about the file that QGIS generates. [Yes, I know, not GRASS' problem.] I didn't log the error message, but basically it complained about the file being too large by I believe 14 bytes.
I'll hack with v.in.ascii a bit more.
Stuart Edwards wrote:
Hi
Stuart
error message:
instead of
I managed to get this command to work (well at least issue no error messages) by using the CSV option. However, the open_office created CSV is was identical to my vim created file except that a comma is used as a delimiter rather than the pipe symbol.
The input format was numeric LL, using the minus sign for W.
Hi
Stuart
error message:
instead of
>>>> error message:
