[GRASS-user] [GRASSLIST:1156] v.digit: Segmentation fault
On GRASS6.0.2 on debian, v.digit is giving segmentation fault. Listing
is given below. What is wronmg?
H.S.Rai
g.list type=vect
vector files available in mapset hsrai:
contourVec digitVec fieldData line line2 v3
v.digit map=v3
Segmentation fault
GRASS 6.0.2 (wg):~/grass/batch >
http://www.fastmail.fm - One of many happy users:
  http://www.fastmail.fm/docs/quotes.html
Hardeep Singh Rai napisa?(a):
Can you reproduce this with any vector, or only this one? What does
"v.info v3" say? If you run "v.build v3", then v.digit - does that help?
Maciek
P.S.
Quit using grasslist@baylor.edu. It is deprecated.
