Does r.in.gdal use the rrd files (the ones that build pyramids to speed up viewing) when importing img files? A bunch of land cover images that I downloaded came with rrd files (in addition to the imgs, and I'm trying to figure out if grass uses them).
Kirk
Kirk,
r.in.gdal does not exactly import overviews from any of it's input formats.
However, GDAL does support overviews in Imagine files (.rrd files) so if
you tried to import a big imagine files withoverviews into a low resolution
location r.in.gdal would pull from an overview to speed up the import.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam@pobox.com
light and sound - activate the windows | http://pobox.com/~warmerdam
and watch the world go round - Rush | President OSGeo, http://osgeo.org
On Jul 27, 2007, at 9:13 AM, Frank Warmerdam wrote:
Kirk,
Thanks Frank,
Does r.in.gdal know to do that automagically (as long as the rrd files are in the same directory as the img files)? or is there a flag that needs to be set on the import?
Kirk
Best regards,
Kirk,
Thanks Frank,
Kirk,
It is automatic as is the nature of GDAL for this sort of thing.
Best regards,
IMO this should make it into the otherwise excellent documentation.
http://www.gdal.org/frmt_hfa.html says regarding write support..
| If overviews are generated, they will be in an external .ovr (GeoTIFF
| file) recognised only by GDAL, not in the .rrd format produced by
| Imagine.
..so one might (wrongfully) believe there's also absolutly no read support
for .rrd files.
