[GRASS-user] Having problems with v.in.ogr
Hi
I am having issues importing a shapefile using v.in.ogr
Using basic command v.in.ogr dsn=shapefile layer=shapefile name output=elev
getting the following areas for every entry
GRASS_INFO_WARNING(29…,50…): Area size 6.5e-11, area not imported.
[warning sign] area size 6.5e-11, area not imported
THe shapefile was generated by a Greenstar 2 GPS receiver (John Deere).
There are many columns in the shapefile (30).
How can i limit the number of columns i read in, and how to set which column is the elevation column (or is ELEVATION okay)?
I am assuming it has something to do with the way the shapefile was genereated and the precision/length of the numeric fields in the database???
Please can ayone help with this?
Also what is a good .dbf viewer for KDE?
Ed
output=elev
GRASS_INFO_WARNING(29..,50..): Area size 6.5e-11, area not imported.
Reduce v.in.ogr's min_area option.
  min_area Minimum size of area to be imported (square units).
             Smaller areas and islands are ignored. Should be
             greater than snap^2
             default: 0.0001
Deere).
could you make a small sample available somewhere?
you can't during import, but you can later with v.db.dropcol
okay)?
I am not sure if there is a vector tool to change a 2D vector + numeric
column into a 3D vector directly.
v.out.ascii + "v.in.ascii z=" would probably do it.
but most GRASS DEM creation tools will let you specify a 2D vector + elev
column name instead of needing a 3D vector as the input.
database???
As long as the datafile is not corrupt you /should/ be able to work with
whatever is in it.
Don't know about KDE, but "dbview -bt" is nice from the command line, and
OpenOffice is probably ok if there are less than a few tens of thousands of
entries.
Hamish
Hi Hamish,
Yes, changing the default grid size fixed my problem. I initially read it as square meters (or assumed), however when i looked at it again i realised my mistake. I have been away most of last week so have not had a chance to progress any further with DEM creation.
As far as making the shapefile available it is around 5mb in size. Also i dont really have any where to put it except one of the commercial sites. However i can still make a copy available if you like.
Ed
output=elev
Reduce v.in.ogr’s min_area option.
greater than snap^2
default: 0.0001
Deere).
you can’t during import, but you can later with v.db.dropcol
okay)?
v.out.ascii + “v.in.ascii z=” would probably do it.
database???
whatever is in it.
Don’t know about KDE, but “dbview -bt” is nice from the command line, and
entries.
Hamish
