Hello
I’m trying to import an HDF5 file and I’m having a few difficulties on “HOW to do this”. Is there any wiki/tutorial that explains how to import remote sensing data such as HDF5 files?
Thanks
Pedro
Hello
Thanks
Pedro
Pedro Roma:
I'm trying to import an HDF5 file and
I'm having a few difficulties on "HOW to do
this". Is there any wiki/tutorial that explains how to
r.in.gdal, with the HDF5 driver:
http://www.gdal.org/frmt_hdf5.html
see the "MODIS" wiki page for examples with HDF4, probably it is
not too different. (sorry if that page is a bit of a mess)
Hamish
Hi
Regarding this. using r.in.gdal it says that selected band do not exist.
About “HDF5 driver”, how can I use that driver using r.in.gdal command?
On Fri, Feb 12, 2010 at 4:26 AM, Hamish <hamish_b@yahoo.com> wrote:
Pedro Roma:
import remote sensing data such as HDF5 files?r.in.gdal, with the HDF5 driver:
http://www.gdal.org/frmt_hdf5.htmlsee the “MODIS” wiki page for examples with HDF4, probably it is
not too different. (sorry if that page is a bit of a mess)Hamish
Hamish:
Pedro:
HiRegarding this. using r.in.gdal it
says that selected band do not exist.About "HDF5
driver", how can I use that driver using r.in.gdal command?
please post the file name, the results of gdalinfo, and the
exact r.in.gdal command line used.
http://grass.osgeo.org/wiki/MODIS
Hamish
Hi
This is the command:
r.in.gdal input=/mnt/GIS/data/HDF5_GEO_200101011450 output=file_out
and the error is:
Projection of input dataset and current location appear to match
ERROR: Selected band (1) does not exist
Thank you
Pedro Roma
On Fri, Feb 12, 2010 at 12:30 PM, Hamish <hamish_b@yahoo.com> wrote:
Hamish:
Pedro:
says that selected band do not exist.About “HDF5
driver”, how can I use that driver using r.in.gdal command?please post the file name, the results of gdalinfo, and the
exact r.in.gdal command line used.see the “MODIS” wiki page for examples with HDF4,
Hamish
On Fri, Feb 12, 2010 at 1:56 PM, Pedro Roma <pedroroma1982@gmail.com> wrote:
Hi
r.in.gdal input=/mnt/GIS/data/HDF5_GEO_200101011450 output=file_outand the error is:
As stated in
you have to specify all the long funky name indicated in SUBDATASETXX.
Looks odd but it is the only way to the the data imported.
Ahhh ok I see
But it’s not possible to GRASS to identify each layer of HDF5 file?
Yes, indeed it looks odd and not very practical :(.
And regarding other products, example CEOS, it’s necessary to specify also CEOS:/file bla bla bla?
Thank you Markus
Pedro
Hi
ERROR: Selected band (1) does not existAs stated in
Hamish:
> and the exact r.in.gdal command line used.
Pedro wrote:
This is the command:r.in.gdal
input=/mnt/GIS/data/HDF5_GEO_200101011450 output=file_outand the error is: Projection of
ok, and what does gdalinfo say about available bands?
did you read this:
(the answer is in the second and third paragraphs.... you have
to tell it which band you want)
and this:
(hint: "band" and "subdataset" are probably the same thing)
Hamish
Hamish wrote:
did you read this:
[snip]
No. As it says a bit further down, after getting info for a specific subdataset: "You may use gdal_translate for reading image bands from this [selected sub-] dataset."
That's why r.in.gdal could not import all bands, because HDF (hierarchical data format) is something like a superdataset with subdatasets, each of these subdatasets may in turn hold several bands (usually only one band).
It is generally a good idea to first read the documentation in
http://www.gdal.org/formats_list.html
before trying to import/export raster maps via gdal
because there are 105 different formats, also CEOS, listed in
where most of your questions are answered ![]()
Not many people know all the little peculiarities of all these formats by heart, most, also those providing answers, usually look up the details of a particular format in the documentation provided.
Markus M
