[GRASS-user] hdf4 missing in gdal 1.6.1-2
sela wrote:
I just realised that the hdf4-library is not included any more in gdal
1.6.1-2 (there is only a hdf5 support left).
Consequently, GRASS (6.4 rc4) does not read or import my ASTER hdf
images any more. I cannot even read the header file. So my question
is: how can I include the hdf4 library into the current gdal-version?
is that from Debian/experimental ?
if so, please consult the DebianGIS mailing list for advice on that, as
the grass project has little control over the issue.
  http://wiki.debian.org/DebianGis
(and take "experimental" and "unstable" at their word)
regards,
Hamish
Thanks for your reply, Hamish.
I have Ubuntu 9.04 installed and I use the repository for GRASS64 rc4 on
http://les-ejk.c.
As far as I know, I have never been using a repos on DebianGIS neither on
UbuntuGIS.
Greetings
Stefan
regards,
Hamish
grass-user mailing list
grass-user@lists.osgeo.org
View this message in context: http://n2.nabble.com/hdf4-missing-in-gdal-1.6.1-2-tp3048480p3048948.html
I just killed gdal 1.6.1-2 and reinstalled gdal-bin 1.5.2-3, and now
everything works, my ASTER-HDF images are readable again. But I am still
wondering why they do not include the hdf4-library in the latest
gdal-version?
http://les-ejk.c.
UbuntuGIS.
Greetings
Stefan
regards,
Hamish
View this message in context: http://n2.nabble.com/hdf4-missing-in-gdal-1.6.1-2-tp3048480p3049068.html
I have a vector layer with category numbers with very very high numbers.
Thats not very useful for further work. Now I want to change the cats to
an ascending order (1,2,3,...,n).
Is that possible in an easy way? Or even if there is a complicated one
it would be great.
Btw, there is no rule I can use to reclassify. Maybe some
'special'-extraction could help I don't see?
Any guess welcome,
Achim
it would be great.
r.reclass can create a reclass map. You can generate the reclass rules
using r.category and awk, e.g.:
r.category oldmap | awk '{print $1,"=",NR}' | r.reclass in=oldmap out=newmap
it would be great.
As the OP is about vectors, here's a vector approach:
v.category option=del
v.category option=add
Moritz
P.S. For posterity, try to use more explicit subject lines for your mails :wink:
