[GRASS-user] Help with v.select with GRASS GIS 7.2
Hi all!
I’m trying to use v.select to find the intersection/crossings of a pipeline path across a stream network…
v.select -r --overwrite ainput=pipeline_streams@teaiii atype=line binput=mvp_path@teaiii btype=line output=mvp_stream_crossings operator=crosses
I’ve tried several options of crosses, intersects, overlap, etc., with and without ‘reverse’, each time getting:
Output:
Processing features…
ERROR: IllegalArgumentException: point array must contain 0 or >1 elements
Any thoughts with this??
Thank you,
Tom
Thomas E Adams, III
1724 Sage Lane
Blacksburg, VA 24060
tea3rd@gmail.com (personal)
tea@terrapredictions.org (work)
1 (513) 739-9512 (cell)
On Mon, Feb 20, 2017 at 10:41 PM, Thomas Adams <tea3rd@gmail.com> wrote:
Hi all!
I'm trying to use v.select to find the intersection/crossings of a pipeline
path across a stream network...
operator=crosses
I've tried several options of crosses, intersects, overlap, etc., with and
without 'reverse', each time getting:
Output:
Processing features...
Could you create an example with the NC sample dataset?
