I compiled grass-6.4.svn_src_snapshot_2008_06_28, in Ubuntu 7.10
./configure -with-cxx -with-gdal=/usr/bin/gdal-config -with-postgres -with-postgres-includes=/usr/includes/postgresql
-with-postgres-libs=/usr/lib/postgresql/8.2/lib -with-tcltk-includes=/usr/include/tcl8.4 -without-mysql -without-odbc
-with-readline -with-fftw -with-fftw-libs=/usr/local/lib -with-freetype --with-freetype-includes=/usr/include/freetype2
-enable-largefile -with-python -with-blas -with-lapack -with-proj-share=/usr/share/proj
make
install
But with this errors:
Errors in:
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/lib/gmath
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/lib/imagery
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/lib/cluster
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/lib/rst/interp_float
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/general/g.transform
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/imagery/i.cluster
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/imagery/i.gensig
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/imagery/i.gensigset
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/imagery/i.group
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/imagery/i.his.rgb
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/imagery/i.maxlik
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/imagery/i.rectify
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/imagery/i.rgb.his
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/imagery/i.smap/shapiro
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/imagery/i.target
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/imagery/i.pca
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/imagery/i.cca
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/imagery/i.fft
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/imagery/i.ifft
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/imagery/i.zc
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/imagery/i.class
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/imagery/i.ortho.photo/libes
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/imagery/i.ortho.photo/menu
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/imagery/i.ortho.photo/photo.2image
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/imagery/i.ortho.photo/photo.2target
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/imagery/i.ortho.photo/photo.camera
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/imagery/i.ortho.photo/photo.elev
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/imagery/i.ortho.photo/photo.init
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/imagery/i.ortho.photo/photo.rectify
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/imagery/i.ortho.photo/photo.target
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/imagery/i.points
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/imagery/i.vpoints
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/ps/ps.map
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/raster/r.param.scale
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/raster/r.resamp.rst
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/raster/r.surf.random
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/raster/r.surf.gauss
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/raster/simwe/simlib
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/raster/simwe/r.sim.water
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/raster/simwe/r.sim.sediment
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/raster/r.in.gdal
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/raster/r.out.gdal
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/raster/r.surf.fractal
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/vector/v.kernel
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/vector/v.surf.rst
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/vector/lidar/lidarlib
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/vector/lidar/v.surf.bspline
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/vector/lidar/v.outlier
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/vector/lidar/v.lidar.correction
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/vector/lidar/v.lidar.edgedetection
/usr/local/grass-6.4.svn_src_snapshot_2008_06_28/vector/lidar/v.lidar.growing
In case of errors please change into the directory with error and run 'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Mon Jul 7 09:16:02 COT 2008
make: *** [default] Error 1
The modules with errros doesn't working, and I need use some this modules.
Need I uninstall and install other version?
How could I uninstall GRASS, for change version?
Can we help me please?
Thanks
John
Jhon Ortiz Trujillo
Bogotá - Colombia
Celular (057) 311 - 5143146
_________________________________________________________________
MSN Video.
http://video.msn.com/?mkt=es-es
