Dear all,
I need to convert some maps like Bmp & Jpeg format files into Shape(.Shp)
format on windows.
errr....
Look, in GIS parlance, bmp and jpg are raster formats. Shapefile is a
vector format.
So, no direct "conversion" between those.
What you would do in a strict GIS environment, is to register
(georeference) those images and then digitize whatever is important to
a vector file.
can you please suggest me any open source tool to convert into shape files.
Most GISes, specially the free ones (GRASS/QGIS) allow you to load
those images and vectorize.
However, I remember seeing something about some program that allow you
to automagically vectorize a raster.
Potrace + Inkscape sounds interesting. Just out of curiosity, does
anyone knows if it could be used to vectorize scanned topo sheets?
Daniel
On Wed, Aug 27, 2008 at 9:04 AM, Paulo Marcondes
<paulomarcondes@gmail.com> wrote:
2008/8/27 Alpha GRASS <alpha.grass@gmail.com>:
Dear all,
format on windows.
errr....
vector format.
a vector file.
While not answering exactly your question, that was the best i could
find in google.
Remember: google is your friend.
Paulo Marcondes = PU1/PU2PIX
-22.915 -42.224 = GG86jc
grass-user mailing list
grass-user@lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/grass-user
2008/8/27 Daniel Victoria <daniel.victoria@gmail.com>:
if you have the sheets by "theme", that could work.
By theme, I mean separate rasters for contour, hydro, roads, etc...
That would be an interesting thing to test. How that would be imported
into grass is one thing I am not sure.
There used to be the way by using Autotrace. You vectorized the raster to the dxf format and imported it into grass by v.in.dxf. The rasters I was working with used the same projection as my location. I just had to make a v.transform on them and voila.
Af far as it can be deduced from the homepage, Autotrace is not developed any more. The page, however, is still there and you can grab the sources. There seems to be a gui as well.
--- On Wed, 27/8/08, Paulo Marcondes <paulomarcondes@gmail.com> wrote:
Subject: Re: [GRASS-user] How to convert BMP & JPEG files to Shape(.shp) format
To: "Daniel Victoria" <daniel.victoria@gmail.com>
Cc: "grassuser" <grass-user@lists.osgeo.org>
Date: Wednesday, 27 August, 2008, 10:10 PM
curiosity, does
topo sheets?
work.
roads, etc...
be imported
>> Shape(.Shp) format on windows.
> errr....
> vector format. So, no direct "conversion" between those.
> to a vector file.
> you to automagically vectorize a raster.
