I'm searching for a way to delineate the perimeter of an area in a raster map. The area is like the result of r.clump, so it is caracterized by a integer number in the raster map. I have no problem in trasforming the raster map in vector with r.to.vect, but the vector is an area, not a line. I need to know the lenght of the contour of the areas. What is the best way to obtain that?
Thank you in advance
Margherita
Eng. Margherita Di Leo
Ph.D. Student Methods and Technologies for Environmental Monitoring
Department of Environmental Engineering and Physics (DIFA)
University of Basilicata Campus Macchia Romana
85100 - Potenza Italy
On 9/17/09, Margherita Di Leo <diregola@gmail.com> wrote:
Hi List,
Margherita
Ph.D. Student
85100 - Potenza
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
beware the dreaded fractal coastline problem.
especially if you are working with a raster map which is likely
to have saw-tooth edges.
it is better to compare areas. you might be able to compare perimeter
length as a ratio of other clumps on the same map, but that's about it.
