[GRASS-user] How to initialize raster maps.
Marcello wrote:
> But there is no way to avoid r.mapcalc, is there?
I doubt you'd get very much faster or more efficient even by
writing your own C module. (it would probably only take you a
minute to create a r.zero module out of the doc/raster/r.example
code; just change "return x;" to "return 0;" and compile.
r.mapcalc "initialized_map=if(base_map>999999,1,0)"
Moritz
r.mapcalc initialized_map=0
tip: to avoid all your scripts breaking when you want to use
grass7, always add a space around the '=' in r.mapcalc.
r.mapcalc "initialized_map = 0"
Hamish
Marcello:
Hamish:
I doubt you’d get very much faster or more efficient even by
code; just change “return x;” to “return 0;” and compile.
Well, out of curiosity, I made the changes to r.example and compiled it. I then made a small script that initializes a map with the dimensions of one of my maps ( 677 x 1114) inside a loop using the three approaches mentioned in this thread:
1 - r.mapcalc “initialized_map=if(base_map>999999,1,0)” # my very smart method :slight_smile:
2 - r.mapcalc initialized_map=0 # Moritz method
3 - r.example input=initialized_map output=zero_map # Hamish idea
Since I initialize rasters 374 times in my original script, I made the loop in this way.
Results:
1 - 49 seconds
2 - 19 seconds
3 - 58 seconds
Bottom line:
  • Thanks Moritz for the tip, it will save me at least 30 seconds from now on.
  • Thanks Hamish, because I never knew r.example existed and it was fun to test the different approaches. But, no, r.example should stay just as that… an example :slight_smile:
Thanks to all.
Marcello.
P.S.:
Hamish:
grass7, always add a space around the ‘=’ in r.mapcalc.
r.mapcalc “initialized_map = 0”
I will keep it in mind from now on. Tks.
