[GRASS-user] How to use a mask with v.surf.idw ?
Dear all,
I would like to know how to use a mask with the v.surf.idw module. I have tried using r.mask with both raster and vector maps, but v.surf.idw always produces a surface encompassing the entire region [0].
Is there any other way of forcing this module to operate within an area of interest?
Thank you.
[0] https://gis.stackexchange.com/questions/244097/v-surf-idw-ignores-mask
Luís Moreira de Sousa
Im Grund 6
CH-8600 Dübendorf
Switzerland
Phone: +41 (0)79 812 62 65
Email: luis.de.sousa@protonmail.ch
URL: https://sites.google.com/site/luismoreiradesousa
On 21/06/17 16:17, Luí­s Moreira de Sousa wrote:
Dear all,
of interest?
As explained in [1]: "Raster input maps are automatically masked if a raster map named MASK exists. The MASK is only applied when reading maps from the disk."
This means that the output of v.surf.idw will always cover the entire computational region. If you want to create a map with null values outside the mask, you can use r.mapcalc "masked_map = interpolated_map" while the mask is active.
Moritz
[1] https://grass.osgeo.org/grass72/manuals/rasterintro.html
Thank you.
Im Grund 6
CH-8600 Dübendorf
Switzerland
Email: luis.de.sousa@protonmail.ch <mailto:luis.de.sousa@protonmail.ch>
grass-user mailing list
grass-user@lists.osgeo.org
[Please keep discussions on the list]
On 22/06/17 09:59, Luí­s Moreira de Sousa wrote:
Thank you Moritz for your reply.
Is there any way to prevent this module from interpolating new values
for the entire region?
Not AFAIK. You could file an enhancement request. I have no idea how difficult it would be to implement this. v.surf.rst has a 'mask' parameter. I don't know when that comes to play in the algorithm, but it might be an inspiration for v.surf.idw.
Moritz
Thank you once more Moritz. I have opened a new ticket for this issue at the bug tracker [0].
Regards
[0] https://trac.osgeo.org/grass/ticket/3363#ticket
Im Grund 6
CH-8600 Dübendorf
Switzerland
-------- Original Message --------
Subject: Re: [GRASS-user] How to use a mask with v.surf.idw ?
Local Time: June 22, 2017 12:29 PM
UTC Time: June 22, 2017 10:29 AM
To: Luí­s Moreira de Sousa luis.de.sousa@protonmail.ch, GRASS user list grass-user@lists.osgeo.org
difficult it would be to implement this. v.surf.rst has a “mask”
parameter. I don"t know when that comes to play in the algorithm, but it
Moritz
