Dear All,
Any body can help me-"How we can set attribute column name from
ascii file heading in point mode creating vector from ascii file(
v.in.ascii )".
Thanks & Regards,
Swapan Ghosh
Dear All,
v.in.ascii )".
Thanks & Regards,
Swapan Ghosh
On 23/05/12 11:07, SWAPAN GHOSH wrote:
Dear All,
v.in.ascii )".
You cannot. You have to explicitely give name and type of column with the columns= parameter. Especially the type of column is important (and difficult to determine automatically) as it determines the type of operations you can do on that data.
You can try to import the data into QGIS with the delimited text plugin, save it as a shapefile and then import it into GRASS, but you have no guarantee that the column type will be recognized correctly.
Moritz
