[GRASS-user] Hyperindex map for genaration of ATLAS, Volume of Water/Earth with reference to a user stated depth datum, Genarate dip/strike from the DEM model
Dear all,
Any one please guide me how I can solve the problem like- " 1. Hyperindex map for genaration of ATLAS, 2. Volume of Water/Earth with reference to a user stated depth datum, 3. Genarate dip/strike from the DEM model "
Thanks & Regards,
Swapan Ghosh
On Wed, Oct 10, 2012 at 8:30 AM, SWAPAN GHOSH <swap.ghsh@gmail.com> wrote:
Dear all,
This driver may help:
http://grass.osgeo.org/gdp/html_grass64/htmlmapdriver.html
See
http://grass.osgeo.org/gdp/html_grass64/r.volume.html
Alternative: work with voxels, then
http://grass.osgeo.org/gdp/html_grass64/r3.stats.html
See:
http://grass.osgeo.org/gdp/html_grass64/r.plane.html
Dear Markus,
Thank you very much. I can solve the problem as per your advice.I have also small request to you that how I can solve the below four problem like-
  • Reading hyperspectral image and then convert it into Grass GIS format.
  • BitMap(Color,Mono and grey scale bitmap back ground)
  • Cut and Fill from two DEM
  • Statistical properties from the DEM using user specified polygon on a specified area of a river
Thanks & Regards,
Swapan Ghosh
Dear all,
  1. Volume of Water/Earth with reference to a user stated depth datum,
See
  1. Genarate dip/strike from the DEM model "
See:
On 10/10/12 13:58, SWAPAN GHOSH wrote:
Dear Markus,
- Reading hyperspectral image and then convert it into Grass GIS format.
Depends on the formet, but always try first with r.in.gdal.
- BitMap(Color,Mono and grey scale bitmap back ground)
Not sure I understand what you are looking for here.
- Cut and Fill from two DEM
r.patch
- Statistical properties from the DEM using user specified polygon on a
v.rast.stats.
Moritz
